2015-05-29 | mcc-kmod: fix revision to build with kernel revision used | Stefan Agner | |
Use a fixed revision of the MCC kernel module which makes sure it builds with the corresponding Vybrid Linux kernel, which also uses a fixed git hash. | |||
2014-12-18 | mcc-kmod: use mcc kernel module from toradex git | Stefan Agner | |
In order to make the MCC kernel module working with our newer kernel some changes had been made on the MCC kernel module. The changes are available on the Toradex Github account. Get the MCC kernel module sources from Github. |
