2015-05-12 | unclutter: change license string to known "PD" | Max Krummenacher | |
PublicDomain is not known to OE | |||
2015-05-12 | graphviz: update to 2.38, not working | Max Krummenacher | |
Neiter graphviz_2.32.0.bb graphviz_2.38.0.bb work with dizzy. Uses python directory from build host. | |||
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-05-12 | recipes: don't use ${PN} as a recipe name placeholder | Max Krummenacher | |
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al. | |||
2015-03-31 | mesa: remove egl, gles instead of using mesa-gl | Max Krummenacher | |
2015-03-31 | giblib: use autotools-brokensep | Max Krummenacher | |
2015-01-23 | rdesktop: workaround issue witherial forwarding | Max Krummenacher | |
2015-01-09 | rdesktop: add rdesktop recipe | Marcel Ziswiler | |
2014-12-11 | xserver-xorg: use the xorg-CVE-2013-6424.patch | Max Krummenacher | |
while at it remove the xserver-xorg.inc file in favour of the identical inc file in the openembedded-core layer. | |||
2014-12-08 | xserver-xorg: fix broken X server rotation on tegras | Marcel Ziswiler | |
Upgrading to 1.14.7 fixes the broken X server rotation issue seen on Apalis/Colibri T20/T30 as noted on our developer website: http://developer.toradex.com/software-resources/arm-family/linux/linux/ release-details?view=all&issue=9562 | |||
2014-12-08 | xserver-xorg: upgrade to 1.14.7 | Marcel Ziswiler | |
This is an upgrade from the former 1.14.4 recipe as found here: http://cgit.openembedded.org/openembedded-core/tree/meta/ recipes-graphics/xorg-xserver?id= b8feee3cf21f70ba4ec3b822d2f596d4fc02a292 | |||
2014-12-08 | eglinfo-x11: add bbappend for tegra | Marcel Ziswiler | |
2014-10-31 | xserver-common_%.bbappend: don't start XDG autostart | Max Krummenacher | |
This is also done by the session manager effectively starting the autostart items twice. | |||
2014-10-30 | xinput-calibrator: remove systemd service | Stefan Agner | |
Remove xinput-calibrator systemd service since autostart is done using /etc/xdg/autostart/xinput_calibrator.desktop. | |||
2014-08-04 | xserver: set epoch to prevent update to later versions | Max Krummenacher | |
HACK: during do_rootfs opkg takes the latest and greatest available in any feed, e.g. one built for another machine without prefered version rather than what PREFERRED_VERSION puts in the MACHINE_ARCH feed so we set the recipe epoch here. Thus for our architecture we're always latest and greatest. | |||
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-08-04 | xserver: tegra: use 1.14.4 from meta-fsl-arm | Max Krummenacher | |
The tegras xdrivers require an 1.14 API Make the xserver ARCH specific | |||
2014-07-15 | vnc: add directvnc and tightvnc recipesV2.2 | Marcel Ziswiler | |
Two popular VNC clients: - DirectVNC based on DirectFB (e.g. without X11) - TightVNC based on X11 (cherry picked from commit ef4113208de357a5b8accd7610f8bf3230125a59) | |||
2014-07-15 | xinput-calibrator.service: only start when lxdm is enabled | Max Krummenacher | |
If the xinput-calibrator.service is enabled but lxdm.service is disabled lxdm was started anyway because of the requires dependency. Replase Requires with Requisite to have xinput-calibrator.service fail instead. (cherry picked from commit e34e6361ecaaa8b148d438d517761bdd084d1a32) | |||
2014-04-03 | gpu-viv-bin-mx6q: add bbappend for no samples | Max Krummenacher | |
adds gpu-viv-bin-mx6q-libraries package which RDEPENDS only the libraries but not the samples. | |||
2014-04-01 | libdrm: update patch to be compatible with thumb2 | Max Krummenacher | |
2014-04-01 | mesa bbappend: update to match bb version | Max Krummenacher | |
2013-10-17 | evdev: backport V2.8.1 from dora | Max Krummenacher | |
V2.7.3 crash when it receives multitouch events | |||
2013-10-09 | xserver: remove the 1.13 recipe, as 1.14 now works | Max Krummenacher | |
2013-10-09 | xserver: fix patching only for the tegras | Max Krummenacher | |
2013-10-07 | xserver: V14, remove pixman_glyph_cache | Max Krummenacher | |
With the propriatry GPU driver, some text is not rendered. e.g. like in this report http://slopjong.de/2012/11/19/problem-with-font-rendering/ -> revert the relevant patch | |||
2013-09-22 | xserver-xf86-config_0.1.bb: don't duplicate that recipe | Max Krummenacher | |
2013-09-22 | remove obsolete file | Max Krummenacher | |
2013-09-22 | mesa: don't provide EGL, GL ES 1.1, GL ES 2.0 for tegras | Max Krummenacher | |
2013-09-22 | graphviz: add recipe | Max Krummenacher | |
2013-09-22 | systemd: adapt to new systemd handling | Max Krummenacher | |
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed | |||
2013-09-22 | x-server: add version 1.13.1 which is removed from core | Max Krummenacher | |
2013-09-22 | xinput-calibrator: menuentry behaves as the first boot calibration | Max Krummenacher | |
- make the menuentry behave as the one time calibration on first boot | |||
2013-09-22 | xinput-calibrator: bbappend updated to use git instead of versioned tarball | Max Krummenacher | |
2013-08-26 | xserver: move all xserver stuff in the same directoryT30_LinuxImageV2.0Beta3_20130820Apalis_T30_LinuxImageV2.0Beta2_20130816 | Max Krummenacher | |
2013-08-26 | xserver: enable xinerame for apalis-t30 platform | Max Krummenacher | |
2013-05-15 | unclutter: add recipe | Max Krummenacher | |
- Unclutter hides your X mouse cursor when you do not need it | |||
2013-04-25 | scrot: add scrot recipe, commandline screen capture utility | Max Krummenacher | |
2012-12-17 | xinput-calibrator: make the menuentry behaviour as the one time calibration ↵ | Max Krummenacher | |
on first boot | |||
2012-10-18 | xinput-calibrator: make this depending on lxdm, not no-display-manager | Max Krummenacher | |
