path: root/recipes-gnome
2016-03-14gvfs_1.10.1.bbappend: don't build with gphotoMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14gtk+3: Disable Wayland backend for the TegrasMax Krummenacher
2016-03-14gvfs: use _remove to not build with sambaMax Krummenacher
2016-03-14gdk-pixbuf_%.bbappend: build for x11 dependend on DISTROFEATURESMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-05-18gvfs: add missing dependency on libgudevMax Krummenacher
2015-03-31gvfs: remove samba from PACKAGECONFIGMax Krummenacher
compiling gvfs with samba support in dizzy does not only pull in smbclient but the full samba package, i.e. 50MB+.
2014-08-04gvfs: don't use samba-client on vybridMax Krummenacher
save space by not requiring smbclient.
2014-08-04Use generic bbappend filesMax Krummenacher
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it.
2014-04-01gdk-pixbuf bbappend: update to match bb versionMax Krummenacher
2013-09-22gdk-pixbuf: change to the new X11DEPENDS for overrideMax Krummenacher
2013-09-22gdk-pixbuf: bbappend updated to 2.26.5Max Krummenacher
2013-06-26gdk-pixbuf: update icon cache on rootfs build timeMax Krummenacher
2012-10-18update in oe-core makes nautilus bbappend obsoleteMax Krummenacher
2012-08-27nautilus depends on gobject-introspection-nativeT20_LinuxImageV2.0Alpha1_20120808Max Krummenacher
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image rename bbappend because coresponding bb does not exist
2012-06-03Initial commitMax Krummenacher
