2015-03-31 | udev-extraconf: replace version with % wildcard | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-04-01 | udev-extraconf: remove space from path | Max Krummenacher | |
If the path is appended by someone else, the space introduces an error | |||
2013-06-26 | udev: don't try to automount mmcblk0bootX | Max Krummenacher | |
- these partitions are not meant to be mounted |
