2015-05-12 | wpa-supplicant: remove bbappend, fixed in bb | Max Krummenacher | |
2015-05-12 | connman: blacklist USB gadget devices | Stefan Agner | |
Connman gained support for USB gadget. The typical usecase is to use USB gadget for tethering. In this use case the module would be the device sharing the connection to the USB host connected to the module. However, our typical use case in mind for RNDIS is a simple ethernet connection between a development host and the module, hence no need for tethering/routing. This however is not easily doable with connman, since connman tries to have one connection online only. When enabling USB gadget as a normal ethernet device, this typically leads to classic ethernet not being configured since the USB RNDIS connection is already up and running. By blacklisting USB gadget, connman won't touch the device and we can use other means of bringing up the network interface. | |||
2015-05-12 | midori.bbappend: move version to % placeholder | Max Krummenacher | |
2015-05-12 | recipes: don't use ${PN} as a recipe name placeholder | Max Krummenacher | |
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al. | |||
2014-12-11 | samba: add quota to the DEPENDS | Max Krummenacher | |
2014-08-04 | openssh: do not use reverse DNS | Max Krummenacher | |
This gets rid of a long timeout when connecting in a network which does not provide reverse DNS. | |||
2014-08-04 | remove obsolete recipe and patch | Max Krummenacher | |
2014-08-04 | connman.service: adapt patch to new upstream version | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-04-01 | openssh bbappend: update to match bb version | Max Krummenacher | |
2014-04-01 | midori bbappend: update to match bb version | Max Krummenacher | |
2014-04-01 | connman bbappend: update to match bb version | Max Krummenacher | |
2013-10-17 | midori: add inital bookmarks and homepage | Max Krummenacher | |
2013-09-22 | wpa-supplicant: workaround missing service file | Max Krummenacher | |
2013-09-22 | openssh: follow update of recipe with bbappend | Max Krummenacher | |
2013-09-22 | systemd: adapt to new systemd handling | Max Krummenacher | |
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed | |||
2013-09-22 | remove obsolete files | Max Krummenacher | |
2013-09-22 | wpa-supplicant: don't install systemd service file | Max Krummenacher | |
- is already installed | |||
2013-09-22 | connman: add a unused .bb to silence a bbappend | Max Krummenacher | |
2013-09-22 | connman: bbappend updated to 1.12 | Max Krummenacher | |
2013-09-22 | connman: bbappend updated to 1.10 | Max Krummenacher | |
2013-07-26 | openssh: give the subpackages there own -dev, -dbg | Max Krummenacher | |
this allows a debug installation of dropbear with openssh-scp, openssh-sftp and openssh-sftp-server | |||
2012-10-19 | connman.service: start the service only when the rootfs is not an NFS mount | Max Krummenacher | |
