2015-05-12 | update to latest u-boot | Max Krummenacher | |
2015-05-12 | update U-Boot and Colibri VFxx Linux to latest git revision | Stefan Agner | |
2015-05-12 | update to latest u-boot | Marcel Ziswiler | |
2015-05-12 | colibri_t20: fix fw_printenv/setenv | Marcel Ziswiler | |
2015-05-12 | tegrarcm/cryptopp: build and use as a static library | Max Krummenacher | |
We need libcryptopp only for a 32bit x86 target for tegrarcm. However linking libcryptopp dynamically and using the distro supplied 32bit compatibility libcryptopp raises an assertion: tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed. Building only a static library with OE, (if native build forcing 32bit) fixes the issue. | |||
2015-05-12 | u-boot: use latest from git | Max Krummenacher | |
While at it remove warning about stripped fw_printenv binary when building u-boot-toradex-fsl-fw-utils. | |||
2015-05-12 | Apalis/Colibri iMX6: kernel/U-Boot update to latest in -next | Max Krummenacher | |
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module. | |||
2015-05-12 | colibri_vf: update to U-Boot 2015.04/Linux 4.0 | Stefan Agner | |
2015-05-12 | apalis/colibri_t20/t30: integrate latest stuff | Marcel Ziswiler | |
2015-05-12 | u-boot-fw-utils: deploy fw_saveenv as symlink | Max Krummenacher | |
2015-05-12 | licenses: fix license string to known values or format | Max Krummenacher | |
2015-05-12 | u-boot-toradex-fsl-fw-utils: fix compile | Max Krummenacher | |
cross strip tool not found without this patch. | |||
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-05-12 | u-boot-fw-utils: fix compiler options | Max Krummenacher | |
With dizzy we got compiler errors when compiling with the new 4.9 gcc. | |||
2015-03-31 | u-boot-fw-utils: fix passing of compiler options | Max Krummenacher | |
Without this the compiler tries to use a soft abi and stops with an error. fatal error: gnu/stubs-soft.h: No such file or directory # include <gnu/stubs-soft.h> | |||
2015-02-03 | colibri-vf: update Linux kernel and U-Boot git hashes | Stefan Agner | |
Also update default defconfig for colibri-vf. | |||
2015-02-02 | alsa-state: update Vybrid default ALSA state | Stefan Agner | |
Update default ALSA state for WM9712 AC97 codec support on 3.18 kernel. | |||
2015-01-09 | u-boot: build additional binary for Apalis iMX6Q 2GB IT | Max Krummenacher | |
The IT variant needs different RAM timings | |||
2014-12-19 | u-boot/u-boot-fw-utils: update all to latest | Max Krummenacher | |
2014-12-19 | colibri_vf: update U-Boot and Linux kernel git hashes | Stefan Agner | |
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze. | |||
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-12-16 | colibri-vf: switch to mainline kernel based on 3.18 | Stefan Agner | |
Switch default kernel recipe to linux-toradex-vf which will build a kernel based on the toradex 3.18-next branch. | |||
2014-12-11 | colibri-vf: update U-Boot | Max Krummenacher | |
2014-12-11 | apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1 | Max Krummenacher | |
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules | |||
2014-11-13 | apalis/colibri_t30: fix fw_setenv | Marcel Ziswiler | |
2014-11-13 | cbootimage/imx-loader/mtd-utils/tegrarcm: fix 32-bit build of our bsp/devtools | Marcel Ziswiler | |
2014-10-31 | apalis/colibri_t30: introduce fw_printenv/setenv | Marcel Ziswiler | |
2014-10-31 | tegrarcm: add include path to sysroot libcryptopp | Max Krummenacher | |
The include path to libcryptopp is hardcoded to the buildhosts /usr/include/... | |||
2014-10-31 | apalis/colibri_t30: fix noisy analogue audio playback | Marcel Ziswiler | |
Fix noisy analogue audio playback by updating initial ALSA state. | |||
2014-10-30 | u-boot: iMX6/VF update to latest from git | Max Krummenacher | |
2014-10-30 | apalis/colibri_t30: latest u-boot git migrated to cbootimage/tegrarcm | Marcel Ziswiler | |
Use latest U-Boot from git. Migrate to using cbootimage and tegrarcm. | |||
2014-10-30 | Add tegrarcm recipe | Marcel Ziswiler | |
2014-10-30 | Add cbootimage recipe | Marcel Ziswiler | |
2014-10-20 | colibri-vf: u-boot: switch to 2014.10 | Stefan Agner | |
Use rebased U-Boot release 2014.10. The README has a new md5sum and U-Boots new build system has default configurations ending with defconfig too. | |||
2014-10-06 | colibri-imx6: add machine specific config files | Max Krummenacher | |
2014-10-06 | colibri-imx6: refactor recipes for new module | Max Krummenacher | |
2014-10-06 | u-boot: remove don't build the examples patch | Max Krummenacher | |
u-boot.inc no longer builds the standalone examples by default so do patch to not do so is no longer needed. The source tree will no longer be marked as git dirty. | |||
2014-08-04 | u-boot: update to latest git version | Max Krummenacher | |
2014-08-04 | colibri-t20: add configuration to u-boot-fw-utils | Max Krummenacher | |
u-boot-fw-utils allows for U-Boot environmenmt access from Linux. Add the needed configuration file for colibri_t20 with a postinst script which choses the right NAND flash sector sizes from /proc/mtd While at it, fix some whitespace issues. | |||
2014-08-04 | u-boot-toradex: update to latest git version | Max Krummenacher | |
2014-08-04 | gpio-export: fix gpios-export.service | Max Krummenacher | |
2014-08-04 | u-boot-fw-utils: add config für colibri-vf and apalis-imx6 | Max Krummenacher | |
2014-08-04 | gpio-export: add recipe for userspace export of gpios | Max Krummenacher | |
2014-08-04 | mcc/m4: use recipes from meta-fsl-arm | Max Krummenacher | |
deleted: recipes-bsp/libmcc/libmcc_1.04.bb deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb | |||
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-05-24 | colibri-vf: use latest u-boot and burnflash | Marcel Ziswiler | |
Use the latest U-Boot and burnflash. | |||
2014-05-07 | u-boot: make use of shared U-Boot branch | Stefan Agner | |
2014-04-30 | colibri-vf: switch to U-Boot 2014.04 and latest git | Stefan Agner | |
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location. | |||
2014-04-05 | u-boot-fw-utils: provide matching recipes | Max Krummenacher | |
With the change to our own u-boot recipes the bbappend to the common u-boot-fw-utils recipe is no longer a sane solution. While at it cleanup COMPATIBLE_MACHINE style. | |||
2014-04-03 | u-boot: apalis-imx6 update to latest git version | Max Krummenacher | |
