2013-09-22 | machine: define SOC-FAMILY, fix ARCH name | Max Krummenacher | |
2013-09-22 | xserver: upgrade Colibri T20 and Apalis T30 to V14 | Max Krummenacher | |
2013-09-22 | machine: force x-server version 1.13.1 | Max Krummenacher | |
- the binary only x-server driver only supports API for 1.13 at the moment - remove a backup file | |||
2013-09-22 | colibri-t20.conf: cleanup | Max Krummenacher | |
2013-06-07 | apalis_t30: use the apalis specific u-boot configuration | Max Krummenacher | |
2013-04-30 | PXA: add a (untested) machine config for PXA | Max Krummenacher | |
- builds a unified kernel usable on Colibri PXA 270, PXA3xx Module Versions V1.x refer: http://git.toradex.com/gitweb/linux-toradex.git/commitdiff/4fd7b3182077613d7e3c93607b98d6b826f89dd8 probably one needs to use the older adapted kernel and u-boot but with kernel options amended by systemd needs - adds a dummy burnflash tarball to not break final packaging | |||
2013-01-29 | Machine: add apalis-t30 for the Apalis-T30 module | Max Krummenacher | |
2013-01-29 | kernel: use the unified recipe | Max Krummenacher | |
2012-11-19 | colibri-t30.conf: | Max Krummenacher | |
- change to hard-float - u-boot entry point set to l4t R16 requirements - cleanup and harmonized with colibri-t20.conf | |||
2012-10-18 | removed *~ backup files from git repo | Max Krummenacher | |
2012-10-18 | define the vfp variant to be used | Max Krummenacher | |
2012-10-18 | update to L4T R16, use abi hard float instead of soft float | Max Krummenacher | |
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-07-21 | removed unneeded apmd from machine features | Max Krummenacher | |
2012-06-03 | Initial commit | Max Krummenacher | |
