qtdemo-init exists in another recipe for qte. When both recipes are
built we get an error during sysroot deployment.
With fido e2fsprogs did split out the package e2fsprogs-resize2fs.
RRECOMMEND it so that it gets picked up during rootfs creation.
With update.sh one creates files on e.g. a SD-card or a tftp server
which enables updating the SW on a module from U-Boot running on
said module.
This commit adds a module type specific directory on that output media
so that update data for multiple module types can be stored on one media.
Generic U-Boot scripts in the media's root directory do select the
matching update data depending on module type.
To flash a large rootfs over tftp the rootfs must be split into chunks
of 64MB on the tftp server.
Add the option '-c' to the update.sh script which does this automatically.
Use 64MB chunks on all module types.
While at it:
- remove the default directory for the -o parameter
- cleanup text and sort variables
Switch to using the temperature Chamber validated 800 MHz BCT
Apalis_T30_2GB_800Mhz.bct.
Please note that for now this is a fixed 800 MHz BCT which does not
allow for memory DVFS (e.g. 400/800 MHz switching like currently only
possible on Colibri T30).
Update defconfig and kernel version to latest version from git. This
also configures the USB Gadget ConfigFS as a module. Add the ConfigFS
module to the list of autoloaded modules.
We noticed that our latest move to using systemd/networkd leaves the
rndis0 interface down. Manually bringing the link up solved the issue.
As a workaround add upping the link to our start-rndis.sh script.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
recipes/images/angstrom-qt-x11-image.bb
While we were checking whether the mkfs.ubifs tool has the magic
--space-fixup option available we never actually enabled that option
to be used when generating our UBIFS root file system images.
Thanks Bhuvan for spotting this having actually been in our update
scripts for almost two years now!
The upstream server currently gives error 403.
$ wget http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
--2015-09-17 10:50:25-- http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
Resolving linuxbrit.co.uk (linuxbrit.co.uk)... 65.110.41.18
Connecting to linuxbrit.co.uk (linuxbrit.co.uk)|65.110.41.18|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2015-09-17 10:50:25 ERROR 403: Forbidden.
(cherry picked from commit 77e6a09a5afeab9f0d550b3319e134ec991f50cf)
Prepare the rootfs for a future kernel which allows to use modesetting.
We've seen newer distros which incorrectly negotiate used cypher with the on
target openssh. Using 6.8 fixes that.
Newer kernels use a user space deamon to control wifi regulatory domains.
Deploy the user space deamon in all images independent on what kernel
version is used.
This reverts commit bd2d32bf3a8460c87849e75ad01e11450d8cda10.
Remove the backport, is part of fido.
Without this the colibri-vf u-boot is not built.
gpu-viv-bin-mx6q -> imx-gpu-viv
with a bunch of subpackages.
kernel-module-mcc is now provided as virtual/kernel-module-mcc.
Pull it in via depends of libmcc and automatically choose the
correct one.
The WM9715L AC97 codec supports two volume modes for audio capturing:
basic (AC97 conform) and extended. The extended range allows smaller
gain steps and a large range, hence use this mode by default.
Now that we exit on failure the test for a user accessible parted must not
return an error code.
On recent Ubuntu distributions gawk no longer supports awk -V which makes
the test fail.
Simulate our awk use case and test the result instead.
Additionally set 'set -e' to exit immediately on errors. Fix places where
a command returns not zero in 'normal' situations.
E.g. A full disk leads otherwise to funny effects.
Allow relative OUT_DIR.
The eMMC layout comments are confusing and in some regards outdated.
Clean it up.
While at it move the calculation of the rootfs file system size to
the rootfs creation to not confuse the rootfs file system size with
the size of the rootfs partition.
Add USB mass storage mishap.
U-Boot now has the command cfgblock which can be used to create a valid
configblock.
Alternatively one can be created with create_configblock.sh.
Cleanup: Use the append operator to add soc-arch/machine specific
packages to IMAGE_INSTALL.
No change in the image is intended.
add the missing _append
remove connman-gnome applet and libwnck which make no sense in a qt image.
gpioconfig depends on gtk+
