2013-10-23u-boot: update to latest git versionColibri_VF50_LinuxImageV2.1Beta1_20131022Colibri_T30_LinuxImageV2.1Beta1_20131022Colibri_T20_LinuxImageV2.1Beta1_20131022Apalis_T30_LinuxImageV2.1Beta1_20131022Max Krummenacher
2013-10-23linux: update to latest git versionsMax Krummenacher
2013-10-22burnflash: Colibri T30: 400MHz BCT, configblockMax Krummenacher
- Use 400MHz BCT on Colibri T30 to allow for 400/800MHz DVFS - Fix configblock name on T30 - Add configblock generator script to recover from lost configblock
2013-10-21feed-config: use the new feed armv7ahf-vfp-neon for T30/VF50Max Krummenacher
2013-10-21hdmi: add udev rule to start an X output on hotplugMax Krummenacher
2013-10-17evdev: backport V2.8.1 from doraMax Krummenacher
V2.7.3 crash when it receives multitouch events
2013-10-17inputrc: use <HOME> <END> to go to begin/end of lineMax Krummenacher
2013-10-17midori: add inital bookmarks and homepageMax Krummenacher
2013-10-17lxpanel: add module dependent browser to launch barMax Krummenacher
For tegra use firefox, for vybrid midori
2013-10-16build: fix cp destination in sample scriptMax Krummenacher
2013-10-16kernel: update to latest git revisionMax Krummenacher
2013-10-16vybrid: backport from meta-fsl-arm master-nextMax Krummenacher
remove when moving to dora branch
2013-10-16machines: T30 and VF50 consitstently use NEON and hard floatMax Krummenacher
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30)
2013-10-16build: add a sample script for setting up the environmentMax Krummenacher
2013-10-16icu: fix SRC_URIMax Krummenacher
2013-10-16local.conf: set sensible defaultsMax Krummenacher
2013-10-16bblayers: remove unneeded layerMax Krummenacher
2013-10-16bblayers.conf: change path to meta-lxdeMax Krummenacher
2013-10-16chromium bbappend: add missing \ charMax Krummenacher
2013-10-14vybrid: backport from meta-fsl-arm master-nextMax Krummenacher
2013-10-14cortex-a5.inc: backport from openembedded-core dora branchMax Krummenacher
revert when moving to dora
2013-10-11images: add a qt4 embedded imageMax Krummenacher
still missing automatic start of a demo (and detecting keyboard, mouse, touch) export QWS_DISPLAY="LinuxFb:/dev/fb:depth=24" export QWS_KEYBOARD="USB:/dev/input/event1" export QWS_MOUSE_PROTO="LinuxInput:/dev/input/event2" qtdemoE -qws
2013-10-11qt4-embedded: configure with -depths genericMax Krummenacher
2013-10-11icu: replace database with minimzed versionMax Krummenacher
2013-10-11feed-config: remove non working feeds, add feeds for T30 VF50Max Krummenacher
- remove links to incompatible architecture feeds - for Colibri T30, Apalis T30 and Colibri VF50 there are compatible feeds - for Colibri T20 there are no compatible feeds
2013-10-11console-image: fix the inclusion of X11Max Krummenacher
2013-10-10colibri-vf50: add the machine, kernel and u-bootMax Krummenacher
- also add the relevant configuration files
2013-10-10libvpx: configure enable-runtime-cpu-detectMax Krummenacher
- make use of NEON if available, decide at runtime
2013-10-10conf: update sample configurationMax Krummenacher
2013-10-10image-fstype: add colibri-vfxx moduleMax Krummenacher
2013-10-10images: cleanup, add colibri-vfxx moduleMax Krummenacher
- Add optimizations needed for the Colibri VFxx modules - Move common stuff to trdx-extra.inc, /etc/timestamp, CAN utils - Cleanup whitespace and commented stuff - Split out gstreamer packages, don't add them on Colibri VFxx angstrom-lxde-image: - Browser for Colibri VFxx is midori for size reasons console-image: - don't add X11 for Colibri VFxx
2013-10-10u-boot-fw-utils: add bbappend to use the same u-boot sourcesMax Krummenacher
2013-10-10mtd-utils: Build native for a 32bit machineMax Krummenacher
We want to deploy mkfs.ubifs as part of the x86 downloader as most distros do not have a recent enough version. To be more universal we need it unconditionaly in a 32bit version.
2013-10-09xserver: remove the 1.13 recipe, as 1.14 now worksMax Krummenacher
2013-10-09xserver: fix patching only for the tegrasMax Krummenacher
2013-10-09xserver: remove bbappend for version 1.11.2Max Krummenacher
2013-10-09i2c-tools: don't install the perl scripts (and thus don't RDEPEND on perl)Max Krummenacher
2013-10-07xserver: V14, remove pixman_glyph_cacheMax Krummenacher
With the propriatry GPU driver, some text is not rendered. e.g. like in this report http://slopjong.de/2012/11/19/problem-with-font-rendering/ -> revert the relevant patch
2013-10-07xserver driver: Add NVidia binaries for L4T R16.3Max Krummenacher
2013-10-07tegrastats: add --once, --help optionsMax Krummenacher
2013-10-07burnflash: Change image filenameMax Krummenacher
- Change image filename for Colibris to start with Colibri_T20 - Fix issue with configblock binary file name on T30 modules - Add various sanity check to fail early and with error message
2013-10-07resizefs.sh: start from current fs size, not from a constMax Krummenacher
2013-10-07u-boot: clean up recipeMax Krummenacher
2013-10-07kernel: fix hash for colibri-t30Max Krummenacher
2013-10-07xserver: upgrade Colibri T30 to V14Max Krummenacher
2013-09-22xserver-xf86-config_0.1.bb: don't duplicate that recipeMax Krummenacher
2013-09-22gdk-pixbuf: change to the new X11DEPENDS for overrideMax Krummenacher
2013-09-22florence: RDEPEND on svg support to draw iconMax Krummenacher
2013-09-22images: use consistent image namesMax Krummenacher
- use consistent image names - while at it build the GLES samples only for a tegra machine
2013-09-22tegrastats: remove dependency on gtk for cmdline toolMax Krummenacher
