Related-to: ELB-2510
Add the patches that fix interferences of kernel modules with backported
modules.
Related-to: ELB-2687
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Add the patch for defconfig to successfully build the backports-5.4.
Related-to: ELB-2388
The patch 0026-apalis_t30-fix-mmc1-cmd-pull-up.patch has already been
removed from the recipe as successfully upstreamed.
Remove the file as well.
Analogous to the following commit from the toradex_4.14-2.3.x-imx
branch on git://git.toradex.com/linux-toradex.git:
b26072eea604461f75a629756ca18a72237281c0
apalis/colibri_imx6/-imx6ull/_imx7_defconfig: fix ip firewall (bpf/cgroup)
Remove upstreamed patch: Commit acab21ffa8c0951f2180f80184c921fa4799c786
'mmc: core: fix possible use after free of host' fixes the issue with
the same change as 0015-Revert-mmc-core-fix-error-path-in-mmc_host_alloc.
0026-apalis_t30-fix-mmc1-cmd-pull-up.patch is now applied upstream
Signed-off-by: Ming Liu <ming.liu@toradex.com>
This file is conflicting with another include file with same name in
meta-toradex-bsp-common layer, and no recipe is actually including this
file, so drop it.
In the thud setups modules no longer load because they seem to be compiled
with pic by default.
E.g. at runtime:
[ 9.302483] apalis_tk1_k20: Unknown symbol _GLOBAL_OFFSET_TABLE_ (err 0)
Adding -fno-pic makes them load again.
(cherry picked from commit c10c7168712fa47e50440a7b7b012118939a3371)
Update linux-toradex-mainline to 4.14.109.
(cherry picked from commit d4511e4a45392799ae157c6632f3944981787c02)
recipes-kernel/linux/linux-toradex_git.bb
Variables from tdx_version.conf are now provided by the distro.
Add defaults in case someone doesn't use our distro.
Heed --sysroot setting.
fixes:
| ERROR: QA Issue: perf: The compile log indicates that host include and/or library paths were used.
| Please check the log '/build/krm/oe-core_3.0/build/tmp/work/apalis_tk1-poky-linux-gnueabi/perf/1.0-r9/temp/log.do_compile' for more information. [compile-host-path]
| cc1: warning: include location "/usr/include/slang" is unsafe for cross-compilation [-Wpoison-system-directories]
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply too high. Keep using the rocko based 2.8 BSP for these machines.
Update linux-toradex-mainline to 4.14.90.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Corrects reset and irq pins for capacitive touch for Aster carrier board.
Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>aödf
Update linux-toradex-mainline to 4.14.72.
While at it drop obsolete linux-toradex-mainline 4.9 recipe.
Unfortunately, perf fails building in rocko since this oe-core commit:
commit 6f9117c0bceeedbfce08647825edf86966457bfc
Author: Hongxu Jia <hongxu.jia@windriver.com>
Date: Tue Apr 24 11:33:47 2018 +0800
perf: make a copy of kernel source to perf workdir
Unfortunately perf in such obsolete kernels is not yet as nicely
separated therefore just copy over some more stuff for it to compile
again.
Latest additions:
- 0024-apalis_t30-enable-broken-hpi-on-emmc.patch
Avoid a rare soft lockup upon installing an image from within Tezi.
- 0025-tegra_defconfig-disable-sound-in-tezi-configuration.patch
Avoid keyboard/mouse being unresponsive for 10-15 Seconds.
- 0026-apalis_t30-fix-mmc1-cmd-pull-up.patch
Avoid issues with higher speed SD cards.
- 0027-apalis_t30-pull-up-sd-card-detect-pins.patch
Avoid floating SD card detect pins.
- 0028-Revert-mmc-tegra-Disable-UHS-I-modes-for-Tegra124.patch
Allow for UHS-I modes on TK1.
- 0029-mmc-tegra-fix-eMMC-DDR-mode.patch
Fix eMMC DDR mode.
- 0030-apalis-tk1-enable-ddr52-mode-on-emmc.patch
Enable eMMC DDR mode.
- 0031-apalis-tk1-force-fixed-ids-for-sdmmc-controllers.patch
Avoid re-ordering of SDMMC controller instances.
- 0032-apalis-tk1-fix-pcie-reset-for-reliable-gigabit-ether.patch
Fix PCIe gigabit bring-up issue on Apalis TK1.
Drop commit c35b518f9ba0 ("clk: tegra: Fix pll_u rate configuration")
which meanwhile got merged into stable.
Add the following patches:
- apalis-t30/tk1-mainline: igb: avoid nvm checksum failure
- apalis_t30: fix can2
- mfd: as3722: disable auto power on when AC OK
Update to NVIDIA's latest Linux for Tegra aka L4T R21.7:
https://developer.nvidia.com/linux-tegra-r217
The following libraries got updated:
4094b811241593224a89a5020e0bef7a08914dea */usr/lib/arm-linux-gnueabihf/tegra/libglx.so
157e8271ba925d1dc7405c4ebaad1b8b8b3f1312 */usr/lib/xorg/modules/drivers/nvidia_drv.so
c1d9de2b619110534437850335c06408648e263b */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_imager.so
2a712cc736f0cfc694e1ae44603bb1c95fc0873e */usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_video.so
25514ded098387ac0260586392308144d6e659fa */usr/lib/arm-linux-gnueabihf/tegra/libnvmm_camera_v3.so
4c2528fa906e1ff8702a9e1cad2b63d261bd2c16 */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_query.so
28ace2c204408e58444497f7fc32a7f6852f98a9 */usr/lib/arm-linux-gnueabihf/tegra/libnvomx.so
4094b811241593224a89a5020e0bef7a08914dea */usr/lib/xorg/modules/extensions/libglx.so
Move the USB device aka gadget fix from Tezi to here.
Add patches to force fixed IDs for SDMMC controllers.
Add patch to fix for PLL_U rate configuration (T30).
Add Apalis T30 specific patch for PCIe fix hacks.
Some patches meanwhile got accepted mainline. Backport those
patches.
Integrate Thierry's fbdev mmap fix allowing legacy applications that use
the mmap() syscall on the fbdev device to map framebuffer memory without
causing a hang. Useful e.g. for Tezi.
While at it also update to 4.14.30.
This reverts commit deec4d3c6702cddd23b572790f8b1728761ff6a2.
While at it also update to 4.14.29.
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
The Device Tree support is now handled by the kernel class. This patch
removes the inclusion of linux-dtb.inc from the kernel recipes in this
layer.
Update to latest Linux LTS 4.14.
Update to NVIDIA's latest Linux for Tegra aka L4T R21.6:
https://developer.nvidia.com/linux-tegra-r216
c0067724f7ea174ac845bcf3262916f4cdc68fee */usr/lib/xorg/modules/extensions/libglx.so
7fdf08dac2661c78aa13d72caa205660435a0591 */usr/lib/xorg/modules/drivers/nvidia_drv.so
61fe4c3e02eee124a0b50e0d2f616701c3093da8 */usr/lib/arm-linux-gnueabihf/tegra/libnvomx.so
c0067724f7ea174ac845bcf3262916f4cdc68fee */usr/lib/arm-linux-gnueabihf/tegra/libglx.so
06ff56f0001e07b9e5271e5d1c8ee78a0ddd299d */usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_video.so
abdccb24f89f1f0e482524569f9b6364c1fff0a9 */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_imager.so
3e9b93e4e3bf24980d025917d694e1f23147837f */usr/lib/arm-linux-gnueabihf/tegra/libnvmm_camera_v3.so
1ee7838597bd9a351b4e241ba947b55d8b4419db */usr/lib/arm-linux-gnueabihf/tegra/libnvparser.so
