Use the d.*Var variant instead.
pushd and popd are not posix compliant.
Instead of patching every app, let's patch mesa to pretend
that we have a normal GPU.
based on: github.com/Gnurou/mesa/commits/renderonly
While at it consistently use a lower case 'v' as with U-Boot and kernel
in meta-toradex-nxp.
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
The regular implementation works.
linux-toradex.inc's functionality is provided with linux-dtb.inc for current
device tree enabled kernels. So don't include both include files.
Prevents
ERROR: QA Issue: kernel-devicetree is listed in PACKAGES multiple times, this leads to packaging errors. [packages-list]
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Update to latest revision which fixes Colibri iMX6D not powerering off but
creating a stacktrace.
Update to latest revision.
While at it remove the module specific override of SRCREV and PR and set
the git branch with its own variable.
While at it use 4 spaces to indent code as customary in recipes.
We have this recipe in meta-fsl-arm-extra.
Convert it to a bbappend and only keep the changes to the bb files.
Add LOCALVERSION and generate a scmversion file to annotate the
Kernel with the Toradex release and a git hash.
Since we use USB Gadget ConfigFS now use libusbg to load the
USB Gadget configuration automatically.
Update defconfig and kernel version to latest version from git. This
also configures the USB Gadget ConfigFS as a module. Add the ConfigFS
module to the list of autoloaded modules.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
SCSI lock device disk support is required for USB mass storage to
work. Also enable asynchronous SCSI scanning by default.
