Update to NVIDIA's latest Linux for Tegra aka L4T R21.6:
https://developer.nvidia.com/linux-tegra-r216
The following libraries got updated:
c0067724f7ea174ac845bcf3262916f4cdc68fee */usr/lib/xorg/modules/extensions/libglx.so
7fdf08dac2661c78aa13d72caa205660435a0591 */usr/lib/xorg/modules/drivers/nvidia_drv.so
61fe4c3e02eee124a0b50e0d2f616701c3093da8 */usr/lib/arm-linux-gnueabihf/tegra/libnvomx.so
c0067724f7ea174ac845bcf3262916f4cdc68fee */usr/lib/arm-linux-gnueabihf/tegra/libglx.so
06ff56f0001e07b9e5271e5d1c8ee78a0ddd299d */usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_video.so
abdccb24f89f1f0e482524569f9b6364c1fff0a9 */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_imager.so
3e9b93e4e3bf24980d025917d694e1f23147837f */usr/lib/arm-linux-gnueabihf/tegra/libnvmm_camera_v3.so
1ee7838597bd9a351b4e241ba947b55d8b4419db */usr/lib/arm-linux-gnueabihf/tegra/libnvparser.so
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
greatest.
in local.conf:
DDC/EDID detection was failing on Apalis TK1 V1.2A on Ixora.
Update to latest Linux LTS 4.9.52, add V1.2 hardware support and prepare
for optional CI top of linux-stable 4.9.y branch builds.
Prepare for snapd integration.
Use the d.*Var variant instead.
pushd and popd are not posix compliant.
Instead of patching every app, let's patch mesa to pretend
that we have a normal GPU.
based on: github.com/Gnurou/mesa/commits/renderonly
While at it consistently use a lower case 'v' as with U-Boot and kernel
in meta-toradex-nxp.
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
The regular implementation works.
linux-toradex.inc's functionality is provided with linux-dtb.inc for current
device tree enabled kernels. So don't include both include files.
Prevents
ERROR: QA Issue: kernel-devicetree is listed in PACKAGES multiple times, this leads to packaging errors. [packages-list]
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Update to latest revision which fixes Colibri iMX6D not powerering off but
creating a stacktrace.
Update to latest revision.
While at it remove the module specific override of SRCREV and PR and set
the git branch with its own variable.
While at it use 4 spaces to indent code as customary in recipes.
We have this recipe in meta-fsl-arm-extra.
Convert it to a bbappend and only keep the changes to the bb files.
Add LOCALVERSION and generate a scmversion file to annotate the
Kernel with the Toradex release and a git hash.
Since we use USB Gadget ConfigFS now use libusbg to load the
USB Gadget configuration automatically.
