path: root/recipes-kernel
2017-04-10linux-toradex_3.10.40: update to latestMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-10linux-toradex-mainline: tk1 mainline, update to 4.9.21Max Krummenacher
2017-04-10linux-toradex_git: update to latestMax Krummenacher
2017-04-07linux: use the new version variablesMax Krummenacher
2017-04-07meta-toradex-tegra: cleanup whitespace useMax Krummenacher
2017-04-07linux-toradex_git: suppress kernel too old warningMax Krummenacher
2017-04-07linux-toradex_git: update to latest -nextMax Krummenacher
2017-04-07linux-toradex_3.10.40: update to latest -nextMax Krummenacher
2017-04-07linux-toradex-*.inc: bb.data.*Var is deprecatedMax Krummenacher
Use the d.*Var variant instead. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07linux: remove bashism from do_configureMax Krummenacher
pushd and popd are not posix compliant. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11linux-toradex_git: update to latestMax Krummenacher
2017-01-11linux-toradex_3.10.40: update to latestMax Krummenacher
2017-01-11apalis-tk1-mainline: Move GPU acceleration support to mesaDominik Sliwa
Instead of patching every app, let's patch mesa to pretend that we have a normal GPU. based on: github.com/Gnurou/mesa/commits/renderonly Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11linux-toradex_3.10.40: update to latest nextMax Krummenacher
2017-01-11u-boot/kernel: update version string to 2.7Max Krummenacher
While at it consistently use a lower case 'v' as with U-Boot and kernel in meta-toradex-nxp. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11apalis-tk1: Mainline kernel machineDominik Sliwa
This patch adds mainline linux based Apalis TK1 machine. It includes compatible recipes for libdrm, mesa, Xorg, and weston. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11linux-toradex_3.10.40: keep cwd in do configure and set version stringMax Krummenacher
2017-01-11linux-toradex_3.10.40: drop own compile implementationMax Krummenacher
The regular implementation works. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11linux-toradex_git: update to latest nextMax Krummenacher
2017-01-11linux-toradex_3.10.40: make sure arch/arm/boot exists in ${B}Max Krummenacher
2017-01-11linux-toradex.inc: make sure arch/arm/boot exists in ${B}Max Krummenacher
2016-11-22linux: tk1: update to include changes for v1.1 modulesApalis_TK1_LinuxImageV2.6.1Beta2_20161122jethroMax Krummenacher
2016-09-29linux t20/t30: update to latestMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29linux tk1: update to latestMax Krummenacher
2016-06-30linux-toradex: update to latestMax Krummenacher
2016-06-30linux: integrate apalis-tk1 and clean-up obsolete device treesMarcel Ziswiler
linux-toradex.inc's functionality is provided with linux-dtb.inc for current device tree enabled kernels. So don't include both include files. Prevents ERROR: QA Issue: kernel-devicetree is listed in PACKAGES multiple times, this leads to packaging errors. [packages-list] Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30linux-toradex: update to latest -nextMax Krummenacher
2016-03-30linux-toradex_git: update to latest on -nextMax Krummenacher
2016-03-14linux-firmware: drop bbappend, changes are now in metaMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-12-15linux-firmware: backport rtl8192cx: Add latest available firmwareMax Krummenacher
2015-12-15linux-toradex-fsl: update to latest revisionMax Krummenacher
Update to latest revision which fixes Colibri iMX6D not powerering off but creating a stacktrace. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15linux-toradex: update to latest revisionMax Krummenacher
Update to latest revision. While at it remove the module specific override of SRCREV and PR and set the git branch with its own variable. While at it use 4 spaces to indent code as customary in recipes. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15linux-toradex_4.1: convert recipe to bbappendMax Krummenacher
We have this recipe in meta-fsl-arm-extra. Convert it to a bbappend and only keep the changes to the bb files. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-11-06Update Tegra Linux kernel to latest.Marcel Ziswiler
2015-11-04Apalis/Colibri iMX6: Update Linux kernel to latestMax Krummenacher
2015-11-04linux: fix B != SMarcel Ziswiler
2015-11-04apalis/colibri_imx6/t20/t30: add version/git hash to KernelStefan Agner
Add LOCALVERSION and generate a scmversion file to annotate the Kernel with the Toradex release and a git hash.
2015-11-04apalis/colibri_imx6: update/load USB Gadget ConfigFS automaticallyStefan Agner
Since we use USB Gadget ConfigFS now use libusbg to load the USB Gadget configuration automatically.
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-21colibri_vf: update/load USB Gadget ConfigFS automaticallyStefan Agner
Update defconfig and kernel version to latest version from git. This also configures the USB Gadget ConfigFS as a module. Add the ConfigFS module to the list of autoloaded modules.
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-10-12apalis-imx6: update kernel to toradex_imx_3.14.28_1.0.0_ga-nextMax Krummenacher
2015-08-13colibri-vf: initial kernel based on upstream 4.1Max Krummenacher
2015-08-07kernel: adapt to oe's new shared work dirMax Krummenacher
2015-08-07colibri-vf: moved to meta-fsl-arm, remove hereMax Krummenacher
2015-06-03colibri_vf: enable SCSI disk required for USB mass storageStefan Agner
SCSI lock device disk support is required for USB mass storage to work. Also enable asynchronous SCSI scanning by default.
2015-05-29mcc-kmod: fix revision to build with kernel revision usedStefan Agner
Use a fixed revision of the MCC kernel module which makes sure it builds with the corresponding Vybrid Linux kernel, which also uses a fixed git hash.
2015-05-18Apalis/Colibri iMX6: use toradex_imx_3.10.17_1.0.0_ga branchMax Krummenacher
2015-05-18Colibri VF: use latest from toradex_vf_4.0 branchMax Krummenacher
