Heed --sysroot setting.
fixes:
| ERROR: QA Issue: perf: The compile log indicates that host include and/or library paths were used.
| Please check the log '/build/krm/oe-core_3.0/build/tmp/work/apalis_tk1-poky-linux-gnueabi/perf/1.0-r9/temp/log.do_compile' for more information. [compile-host-path]
| cc1: warning: include location "/usr/include/slang" is unsafe for cross-compilation [-Wpoison-system-directories]
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply too high. Keep using the rocko based 2.8 BSP for these machines.
Unfortunately, perf fails building in rocko since this oe-core commit:
commit 6f9117c0bceeedbfce08647825edf86966457bfc
Author: Hongxu Jia <hongxu.jia@windriver.com>
Date: Tue Apr 24 11:33:47 2018 +0800
perf: make a copy of kernel source to perf workdir
Unfortunately perf in such obsolete kernels is not yet as nicely
separated therefore just copy over some more stuff for it to compile
again.
