path: root/recipes-kernel/perf/perf.bbappend
2019-03-06perf: fix search path to slangMax Krummenacher
Heed --sysroot setting. fixes: | ERROR: QA Issue: perf: The compile log indicates that host include and/or library paths were used. | Please check the log '/build/krm/oe-core_3.0/build/tmp/work/apalis_tk1-poky-linux-gnueabi/perf/1.0-r9/temp/log.do_compile' for more information. [compile-host-path] | cc1: warning: include location "/usr/include/slang" is unsafe for cross-compilation [-Wpoison-system-directories] Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06apalis/colibri-t20 -t30: drop machinesMax Krummenacher
These machines use an old Nvidia provided downstream kernel 3.1.10. They are no longer compatible with more recent sysroot components, e.g. libc, xserver et. al. The maintenance burden to keep the userspace components in their old version becomes simply too high. Keep using the rocko based 2.8 BSP for these machines. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-09-27perf: fix build with even older kernelMarcel Ziswiler
Unfortunately, perf fails building in rocko since this oe-core commit: commit 6f9117c0bceeedbfce08647825edf86966457bfc Author: Hongxu Jia <hongxu.jia@windriver.com> Date: Tue Apr 24 11:33:47 2018 +0800 perf: make a copy of kernel source to perf workdir Unfortunately perf in such obsolete kernels is not yet as nicely separated therefore just copy over some more stuff for it to compile again. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
