2017-11-29 | kernel recipes: automatically update to latest -next through override | Max Krummenacher | |
This can be used e.g. for a CI setup to do nightly builds of latest and greatest. To use HEAD of xxx-next instead of the pinned version one would add in local.conf: MACHINEOVERRIDES =. "use-head-next:" Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2017-10-05 | kernel recipes: update to latest | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com> | |||
2017-07-01 | linux-toradex_git: update to latest | Marcel Ziswiler | |
2017-04-10 | linux-toradex_git: update to latest | Max Krummenacher | |
2017-04-07 | linux: use the new version variables | Max Krummenacher | |
2017-04-07 | linux-toradex_git: suppress kernel too old warning | Max Krummenacher | |
2017-04-07 | linux-toradex_git: update to latest -next | Max Krummenacher | |
2017-04-07 | linux: remove bashism from do_configure | Max Krummenacher | |
pushd and popd are not posix compliant. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2017-01-11 | linux-toradex_git: update to latest | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2017-01-11 | linux-toradex_git: update to latest next | Max Krummenacher | |
2016-09-29 | linux t20/t30: update to latest | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-06-30 | linux-toradex: update to latest | Max Krummenacher | |
2016-06-30 | linux-toradex: update to latest -next | Max Krummenacher | |
2016-03-30 | linux-toradex_git: update to latest on -next | Max Krummenacher | |
2015-12-15 | linux-toradex: update to latest revision | Max Krummenacher | |
Update to latest revision. While at it remove the module specific override of SRCREV and PR and set the git branch with its own variable. While at it use 4 spaces to indent code as customary in recipes. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2015-11-06 | Update Tegra Linux kernel to latest. | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2015-11-04 | linux: fix B != S | Marcel Ziswiler | |
2015-11-04 | apalis/colibri_imx6/t20/t30: add version/git hash to Kernel | Stefan Agner | |
Add LOCALVERSION and generate a scmversion file to annotate the Kernel with the Toradex release and a git hash. | |||
2015-11-03 | Update Linux kernel and U-Boot to latest. | Marcel Ziswiler | |
2015-08-07 | kernel: adapt to oe's new shared work dir | Max Krummenacher | |
2015-05-18 | Apalis/Colibri T20/T30: use tegra branch | Max Krummenacher | |
2015-05-18 | Apalis/Colibri T20/T30: update kernel to latest in -next | Max Krummenacher | |
2015-05-12 | apalis/colibri_t20/t30: integrate latest stuff | Marcel Ziswiler | |
2015-03-19 | tegras: update to latest kernel | Marcel Ziswiler | |
This contains some eMMC fixes for Apalis/Colibri T30 as well as a CSI-2 fix for Apalis T30 and an ACM fix. | |||
2015-02-03 | tegras: update git hash of Linux kernel | Stefan Agner | |
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-12-18 | tegras: update to latest kernel | Marcel Ziswiler | |
This kernel can be used on latest Apalis T30 V1.1A hardware with Toshiba eMMC and optional UHS SD cards in MMC slot. | |||
2014-11-13 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: rev kernel version to V2.3b4 | Marcel Ziswiler | |
2014-10-30 | linux: tegra latest from git | Marcel Ziswiler | |
2014-09-03 | linux-toradex: update to latest | Max Krummenacher | |
This pulls in the fix for PCIe rarely unavailable at boot. Branch changed from colibri to tegra | |||
2014-08-04 | kernel: update to latest on git.toradex.com | Max Krummenacher | |
2014-08-04 | t20, t30: update kernel to latest in git | Max Krummenacher | |
2014-05-07 | linux-toradex: rename linux.inc to avoid layer order dependency | Stefan Agner | |
The include files (such as linux.inc) are not resolved by priority but on layer order instead. This can lead to build errors in case the layers in BBLAYERS are ordered differently. | |||
2014-03-18 | kernel Txx: update to latest | Max Krummenacher | |
2014-02-10 | kernel/u-boot: update to latest git | Stefan Agner | |
2013-12-02 | kernel: update to latest git | Max Krummenacher | |
2013-11-05 | Use double-quotes to make script work using dash (debian/ubuntu default) | Stefan Agner | |
2013-10-23 | linux: update to latest git versions | Max Krummenacher | |
2013-10-16 | kernel: update to latest git revision | Max Krummenacher | |
2013-10-07 | kernel: fix hash for colibri-t30 | Max Krummenacher | |
2013-09-22 | kernel: update to latest in git | Max Krummenacher | |
2013-09-22 | kernel: hack, CFLAGS should not require contradicting soft and hard float | Max Krummenacher | |
2013-08-19 | kernel: update to latest git version | Max Krummenacher | |
2013-06-26 | kernel: update to latest git revision for T30 kernels | Max Krummenacher | |
2013-05-01 | kernel: change pxa git version | Max Krummenacher | |
2013-03-20 | kernel: update to latest apalis kernel | Max Krummenacher | |
2013-03-04 | T30 kernel: next image will be beta1 | Max Krummenacher | |
2013-03-04 | kernel: update Apalis kernel, comments to full-hd & camera config | Max Krummenacher | |
