All of meta-jetson-tk1 has been moved into meta-toradex-tegra as updates
were needed. Drop meta-jetson-tk1.
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply too high. Keep using the rocko based 2.8 BSP for these machines.
prevents warning:
| Applying patch macro_tweak.patch
| patching file xorg-server.m4
| Hunk #1 succeeded at 28 with fuzz 2.
with xorgproto
see openembedded-core commit 460a2b27af8d023b27703b491331c8cbe7aad0ff
While at it, remove unneeded install append as the file removed no longer exists.
- add the original xserver-xorg.inc which matched the 1.14.4 recipe as the
current one is no longer compatible with the older xserver.
- renamed to xserver-xorg-1.14.7.inc
- merge in OE specific changes from current xserver-xorg,inc.
- merge bbappend into the bb file, we are the only user of this recipe.
- set the compatible machine to SOC-Family rather than specific machines.
Instead of patching every app, let's patch mesa to pretend
that we have a normal GPU.
based on: github.com/Gnurou/mesa/commits/renderonly
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
With the update 'xf86-input-evdev: Upgrade 2.9.2 -> 2.10.0' this file is
provided by the evdev recipe.
The Vybrid xorg.conf should not be part of the Tegra BSP.
Upstream has already fixed the GCC 5 problem, so use the patch from upstream.
Signed-off-by: Ross Burton <ross.burton@intel.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Backport a patch from fedora details are in patch header
Change-Id: I6b8dfaae3b751071bf8b0d88b15a4f95c19877f6
Signed-off-by: Khem Raj <raj.khem@gmail.com>
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
while at it remove the xserver-xorg.inc file in favour of the identical
inc file in the openembedded-core layer.
Upgrading to 1.14.7 fixes the broken X server rotation issue seen on
Apalis/Colibri T20/T30 as noted on our developer website:
http://developer.toradex.com/software-resources/arm-family/linux/linux/
release-details?view=all&issue=9562
This is an upgrade from the former 1.14.4 recipe as found here:
http://cgit.openembedded.org/openembedded-core/tree/meta/
recipes-graphics/xorg-xserver?id=
b8feee3cf21f70ba4ec3b822d2f596d4fc02a292
HACK: during do_rootfs opkg takes the latest and greatest available
in any feed, e.g. one built for another machine without prefered version
rather than what PREFERRED_VERSION puts in the MACHINE_ARCH feed
so we set the recipe epoch here. Thus for our architecture we're
always latest and greatest.
The tegras xdrivers require an 1.14 API
Make the xserver ARCH specific
With the propriatry GPU driver, some text is not rendered.
e.g. like in this report
http://slopjong.de/2012/11/19/problem-with-font-rendering/
-> revert the relevant patch
