fixes:
| ERROR: libgstnvegl-21.5.0-r0 do_package_qa: QA Issue: libgstnvegl: The compile log indicates that host include and/or library paths were used.
Please check the log '/build/krm/oe-core_3.0/build/tmp/work/cortexa15hf-neon-poky-linux-gnueabi/libgstnvegl/21.5.0-r0/temp/log.do_compile' for more information. [compile-host-path]
| ERROR: libgstnvegl-21.5.0-r0 do_package_qa: QA run found fatal errors. Please consider fixing them.
| ERROR: libgstnvegl-21.5.0-r0 do_package_qa: Function failed: do_package_qa
| ERROR: Logfile of failure stored in: /build/krm/oe-core_3.0/build/tmp/work/cortexa15hf-neon-poky-linux-gnueabi/libgstnvegl/21.5.0-r0/temp/log.do_package_qa.15826
| ERROR: Task (/build/krm/oe-core_3.0/build/../layers/meta-toradex-tegra/recipes-multimedia/libgstnvegl/libgstnvegl_21.5.0.bb:do_package_qa) failed with exit code '1'
tegra124m now depends on nouveau and tegra to be configured.
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply too high. Keep using the rocko based 2.8 BSP for these machines.
nouveau / tegra has been upstreamed, thus drop the patches.
While at it create it with git which leads to a changed file name.
0001-gallium-add-renderonly-library.patch:
added upstream
0004-gallium-add-tegra-support.patch, 0008-remove-dependency-on-libdrm_tegra.patch
fix patch conflicts
While at it also update the comment in recipes-graphics/mesa/mesa_%.bbappend.
reorder assignments to be similar between tegra, tegra124, tegra124m
remove unneeded COMPATIBLE_MACHINE assignement.
Instead of patching every app, let's patch mesa to pretend
that we have a normal GPU.
based on: github.com/Gnurou/mesa/commits/renderonly
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
Moving from patching the "*.pc" files to patching there "*.pc.in" files
should hopefully make the patch more independent of the mesa version.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
