Mainline (sources.denx.de) has all the functionality needed for
Apalis TK1. Build directly from the mainline repo.
Add a bbappend which makes the cboot image format.
Related-to: ELB-4090
Bump SRCREV hashes as used in build of Thu Oct 14 22:13:16 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 453
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/453
Signed-off-by: ci.toradex <cicd@toradex.com>
(cherry picked from commit 54b10a73af4a56999b8b5fbb8707adcee5c5b482)
Bump SRCREV hashes as used in build of Tue Sep 21 22:52:09 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 427
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/427
(cherry picked from commit 8658abd984d327037eeaa601aa1472c4bf7b02df)
Bump SRCREV hashes as used in build of Mon Aug 30 13:56:21 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 407
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/407
(cherry picked from commit d4ef0a4584e04b14a6ba368b8cdf8592af43d3bb)
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
Bump SRCREV hashes as used in build of Wed Aug 4 04:59:48 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 381
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/381
(cherry picked from commit f58026172d3c32a9c8026287370ae813d9f14fc5)
Bump SRCREV hashes as used in build of Thu Jun 24 23:53:16 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 343
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/343
(cherry picked from commit e37959a52f2cea3a2a2f0c4f165a60715c817565)
(cherry picked from commit a4a813df625b87ac004032fa29bfc730409cc2fc)
While we did rename the branch we forgot to also rename this recipe. Fix
this.
Fixes commit a21f73d1e08e ("u-boot-toradex: update to 2020.07")
(cherry picked from commit 1f19651ec747c4842dfd0dba25bc056322f2edac)
Bump SRCREV hashes as used in build of Fri Apr 2 22:46:52 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 265
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/265
cherry picked from commit 6b5cc7b and 39a2614
Bump SRCREV
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 231
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/231
Squashed:
(cherry picked from commit a0f00032e59ea7db45e46eea35a221ede499aefd)
(cherry picked from commit b214067b27204f471cf405a1e3997d3da233a8f9)
(cherry picked from commit 2fa40a70b28efedefa4357519b9a92e92f52415d)
(cherry picked from commit b5179b050062a29c2fe0bdfc1717b616c4f1630e)
Change to use the stable symlink to the emmc boot area to specify
the location of the U-Boot environment.
Related-to: ELB-3293
(cherry picked from commit 4cea50134bc3000094d9d285c9711b72f8164c7f)
Bump SRCREV hashes as used in build of Fri Oct 30 22:10:03 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 115
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/115
(cherry picked from commit 1e47313b76cddf103e79a872b652dab7d1c7e062)
Bump SRCREV hashes as used in build of Wed Sep 30 15:34:14 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 84
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/84
Bump SRCREV hashes as used in build of Tue Sep 29 12:08:03 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 81
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/81
2020.07 is reworked to use python3 so the patch which made 2019.07
build in a python3 only enviromenent can be dropped.
Use the 2020.07 branch also with use-head-next.
Fixes commit a21f73d1 ("u-boot-toradex: update to 2020.07")
Related-to: ELB-2758
The changes include:
- Drop PREFERRED_PROVIDER_u-boot-fw-utils from machine conf.
- Drop u-boot-toradex-fw-utils-tk1 recipe.
- Drop fw_unlock_mmc.sh, that's not needed for libubootenv.
- Drop reference to u-boot-toradex-initial-env.inc, that's been
removed from BSP common layer.
Related-to: ELB-2553
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit eef28a0a1e16a0d116192f8ac5a97531d2546f9f)
(cherry picked from commit 3e3a33523b73302d09db47a21e069ae97c159efa)
(cherry picked from commit ab0527430fa9081ef594c6f2e49a0b7e81f6fc00)
PREFERRED_PROVIDER_u-boot should be 'u-boot-toradex-tk1' instead of
'u-boot-toradex', also set PROVIDES += "u-boot" in u-boot-tk1 recipe.
(cherry picked from commit c9180b9e9b1231c8139bbfb47f51acb5692235dc)
They are not needed any more since we upgraded to 2019.07.
(cherry picked from commit 8048bf5cd90a923f6879f1ba714c22e3736fc245)
Rename the apalis-tk1-mainline machine to the now dropped
apalis-tk1 machine name.
Related-to: ELB-2733
(cherry picked from commit 0bf55088d1f34338dd04f83d6b90b7a72f6867de)
The downstream kernel gets to old to be used with the new zeus
userspace components. Drop the machine.
(cherry picked from commit d13caaba2d90f856b944ebde44967b679d3eb3a9)
Related-to: ELB-2510
(cherry picked from commit 7880c26275385d30ce2d7d6c45065764e0fd2472)
Debugging reveals that it is really also expecting certain firmware at
the original path:
[ 134.878913] firmware tegra12x!vic03_ucode.bin: firmware: requesting tegra12x/vic03_ucode.bin
So make a symbolic link rather then copying them.
Without older systemd's firmware usermode helper fallback in place using
an alternative file name leads to a very long timeout. Fix this by
linking the alternative nameed firmware to the one tried first.
(cherry picked from commit 5d206eb3265bc6bc96442ffcd1cc4ce1f80f0714)
(cherry picked from commit 71f68117693bfd479774aac42412a18fdf77a2e8)
OE post zeus dropped Python 2. Provide a workaround so that one can still
build the TK1 U-Boot. When we update U-Boot to 2020.01 or later Python 3
will be supported and this patch can be reverted.
Completes '691b446 u-boot.inc: use python3 for build'.
OE dropped python2 support.
Unify u-boot.inc with openembedded-core which now uses python3 for the build.
(cherry picked from commit 8d3d527425b592480900d006c76694877755486a)
recipes-kernel/linux/linux-toradex-mainline_4.14.bb
recipes-kernel/linux/linux-toradex_3.10.40.bb
Use toradex-u-boot-localversion class to implement the new versioning
scheme for U-Boot.
Otherwise the picked u-boot.inc file depends on the bblayers variable.
Recent OE adds additional shared object checks which errors out on the way
the binary Tegra drivers are injected.
Rework the recipes, so that
- mesa no longer PROVIDE any OpenGL shared objects and the binaries.
- linux-driver-package now depends on mesa to install development headers
- linux-driver-package PROVIDE and RPROVIDE the OpenGL shared objects.
- linux-driver-package drops the additional arm-linux-gnueabihf/tegra path
to the *.so* files.
- the apalis-tk1 machine PREFERS linux-driver-package as the OpenGL provider.
While at it unify whitespace usage.
This commit does not change any configuration or behaviour, it prepares
for a rework of the recipe.
The gstreamer plugins now require addional runtime depends or one gets
qa errors of the following form:
| ERROR: linux-driver-package-21.7.0-r7 do_package_qa: QA Issue: /usr/bin/nvgstplayer-1.0 contained in package linux-driver-package-nvgstapps
| requires libgstvideo-1.0.so.0, but no providers found in RDEPENDS_linux-driver-package-nvgstapps? [file-rdeps]
meta-openembedded dropped gstreamer 0.10 with commit 010c2f388.
There is not a generic license called
"FREESCALE_SEMICONDUCTOR_SOFTWARE_LICENSE_AGREEMENT", drop it, use
"CLOSED" instead, this fixes a following QA warning:
| tdx-k20-fw: No generic license file exists for: FREESCALE_SEMICONDUCTOR_SOFTWARE_LICENSE_AGREEMENT in any provider
Also remove a relative path reference in LIC_FILES_CHKSUM.
commit 8691ba636cb2 allowed to also use SysV init. However, if only systemd
is configured in DISTRO_FEATURES the content of /etc/init.d is deleted
after the install step. This results in the scripts nv and nvfb not being
present.
Fix this by installing them additionally in /usr/bin so that the systemd
service can call them.
Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
While at it append -tk1 to PN to have a name different from the u-boot recipe
name for our NXP based SoM and set the prefered provider accordingly.
Assign the systemd service in the package providing them.
Prevents the following do_rootfs error if linux-driver-package is installed
but linux-driver-package-*boot is not:
| WARNING: linux-driver-package.postinst returned 1, marking as unpacked only, configuration required on target.
| ERROR: Postinstall scriptlets of ['linux-driver-package'] have failed. If the intention is to defer them to first boot,
| then please place them into pkg_postinst_ontarget_${PN} ().
This is caused by sytemctl trying to enable the not existing services nv.service and nvfb.service.
Update linux-toradex-mainline to 4.14.109.
(cherry picked from commit d4511e4a45392799ae157c6632f3944981787c02)
recipes-kernel/linux/linux-toradex_git.bb
(cherry picked from commit 0f59e154bfebd18f4f9eb11a31912ad5cb7e0c93)
