Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
to meta-fsl-arm-extra.
Introduce/update postinst code to dynamically adjust fw_env.config and
fw_unlock_mmc.sh shell profile extension script to cope with our new
unified eMMC layout:
boot area partition 1 aka primary eMMC boot sector:
with U-Boot boot loader and the U-Boot environment before the
configblock at the end of that boot area partition
Introduce SRCBRANCH notation for easier switching to our -next branch.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
And use 2015.04-toradex branch
We need libcryptopp only for a 32bit x86 target for tegrarcm.
However linking libcryptopp dynamically and using the distro supplied 32bit
compatibility libcryptopp raises an assertion:
tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed.
Building only a static library with OE, (if native build forcing 32bit)
fixes the issue.
While at it remove warning about stripped fw_printenv binary
when building u-boot-toradex-fsl-fw-utils.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
With dizzy we got compiler errors when compiling with the new 4.9 gcc.
Without this the compiler tries to use a soft abi and stops with an error.
fatal error: gnu/stubs-soft.h: No such file or directory # include <gnu/stubs-soft.h>
Also update default defconfig for colibri-vf.
The IT variant needs different RAM timings
Two last minute fixes: Default Product/Vendor ID for USB peripheral
in U-Boot and fix for the USB peripheral RNDIS freeze.
Switch default kernel recipe to linux-toradex-vf which will build
a kernel based on the toradex 3.18-next branch.
Update to a U-Boot and Kernel which can be used for Apalis iMX6
HW version V1.0 and V1.1.
Also deploy additional device tree for Apalis iMX6 V1.0 modules
The include path to libcryptopp is hardcoded to the buildhosts /usr/include/...
Fix noisy analogue audio playback by updating initial ALSA state.
Use latest U-Boot from git.
Migrate to using cbootimage and tegrarcm.
Use rebased U-Boot release 2014.10. The README has a new md5sum
and U-Boots new build system has default configurations ending
with defconfig too.
u-boot.inc no longer builds the standalone examples by default so
do patch to not do so is no longer needed.
The source tree will no longer be marked as git dirty.
u-boot-fw-utils allows for U-Boot environmenmt access from Linux.
Add the needed configuration file for colibri_t20 with a postinst script
which choses the right NAND flash sector sizes from /proc/mtd
While at it, fix some whitespace issues.
deleted: recipes-bsp/libmcc/libmcc_1.04.bb
deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb
deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb
