path: root/recipes-bsp/u-boot/files
2019-03-06apalis/colibri-t20 -t30: drop machinesMax Krummenacher
These machines use an old Nvidia provided downstream kernel 3.1.10. They are no longer compatible with more recent sysroot components, e.g. libc, xserver et. al. The maintenance burden to keep the userspace components in their old version becomes simply too high. Keep using the rocko based 2.8 BSP for these machines. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06u-boot: fix build error with dtc headers in sysrootMax Krummenacher
...recipe-sysroot-native/usr/include/libfdt_env.h:70:30: error: conflicting types for 'fdt64_t' typedef uint64_t FDT_BITWISE fdt64_t; ^~~~~~~ In file included from <command-line>:0:0: ...git/include/libfdt_env.h:19:16: note: previous declaration of 'fdt64_t' was here typedef __be64 fdt64_t; ^~~~~~~ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06Revert "u-boot: fix build error with dtc headers in sysroot"Max Krummenacher
This reverts commit 8f9fb0502e052276bdb4d349af5e652e193543ff.
2018-06-18u-boot-toradex: apalis-t30: generate cbootimageMarcel Ziswiler
Generate cbootimage already during build as required for Toradex Easy Installer BSP package. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-12-20u-boot-fw-utils: follow the compile fixes for native/cross used in oe-coreMax Krummenacher
The U-Boot Makefile has a unusual way of compiling the user space tools which results in the wrong toolchain (native vs. target) being used. Drop our downstream fix in favour of how openembedded-core does this now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-05u-boot-toradex: apalis-tk1/apalis-tk1-mainline: generate cbootimageMarcel Ziswiler
Generate cbootimage already during build as required for Toradex Easy Installer BSP package. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-01-11apalis-tk1: Mainline kernel machineDominik Sliwa
This patch adds mainline linux based Apalis TK1 machine. It includes compatible recipes for libdrm, mesa, Xorg, and weston. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11u-boot: upgrade to 2016.11 based versionMax Krummenacher
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11u-boot: fix compileMax Krummenacher
fix errors due to missing uint* types. Move to u-boot git. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-08-17u-boot-toradex-fw-utils: fix bashismmeta-toradex_splitStefan Agner
Do not use the function keyword, then the script works fine with with Busybox' shell implementation. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17u-boot-fw-utils: use negative offset for environmentStefan Agner
Rely on newly implemented configuration functionality to locate the environment at the end of the boot partition. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30u-boot: get rid of obsolete patchesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2015-10-30apalis/colibri_imx6/t30: u-boot-fw-utils: update fw_printenv/setenvMarcel Ziswiler
Introduce/update postinst code to dynamically adjust fw_env.config and fw_unlock_mmc.sh shell profile extension script to cope with our new unified eMMC layout: boot area partition 1 aka primary eMMC boot sector: with U-Boot boot loader and the U-Boot environment before the configblock at the end of that boot area partition
2015-06-16base-files/u-boot-toradex-fw-utils: move MMC unlockStefan Agner
The mmc unlock function causes troubles when using Poky reference distribution since Poky uses the busybox shell: /etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "(" This avoids X getting at all. This patch does not solve the underlying problem, but works around it by moving the script to the u-boot-toradex-fw-utils recipe, which is not installed by the Poky images by default.
2014-10-06u-boot: remove don't build the examples patchMax Krummenacher
u-boot.inc no longer builds the standalone examples by default so do patch to not do so is no longer needed. The source tree will no longer be marked as git dirty.
2014-08-04colibri-t20: add configuration to u-boot-fw-utilsMax Krummenacher
u-boot-fw-utils allows for U-Boot environmenmt access from Linux. Add the needed configuration file for colibri_t20 with a postinst script which choses the right NAND flash sector sizes from /proc/mtd While at it, fix some whitespace issues.
2013-09-22u-boot: don't build the examplesMax Krummenacher
- they do fail because they don't heed the private libgcc
2012-06-03u-boot base from meta instead of a copy from meta-tiMax Krummenacher
fix u-boot to no longer fail at runtime, (write beyond array)
