2019-04-24 | alsa: apalis-tk1-mainline: add initial asound.state and asound.conf | Philippe Schenker | |
Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> (cherry picked from commit 0f59e154bfebd18f4f9eb11a31912ad5cb7e0c93) | |||
2019-03-06 | apalis/colibri-t20 -t30: drop machines | Max Krummenacher | |
These machines use an old Nvidia provided downstream kernel 3.1.10. They are no longer compatible with more recent sysroot components, e.g. libc, xserver et. al. The maintenance burden to keep the userspace components in their old version becomes simply too high. Keep using the rocko based 2.8 BSP for these machines. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-11-22 | alsa: apalis-tk1: add initial asound.state | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2014-10-31 | apalis/colibri_t30: fix noisy analogue audio playback | Marcel Ziswiler | |
Fix noisy analogue audio playback by updating initial ALSA state. | |||
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-01-29 | alsa: add Apalis-T30 initial asound.state | Max Krummenacher | |
2012-12-31 | T30: add specific alsa asound.state | Max Krummenacher | |
2012-12-31 | update u-boot and kernel git versions | Max Krummenacher | |
remove testfile | |||
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
