path: root/openembedded-layer/recipes-benchmark
2019-03-06apalis/colibri-t20 -t30: drop machinesMax Krummenacher
These machines use an old Nvidia provided downstream kernel 3.1.10. They are no longer compatible with more recent sysroot components, e.g. libc, xserver et. al. The maintenance burden to keep the userspace components in their old version becomes simply too high. Keep using the rocko based 2.8 BSP for these machines. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11glmark2: fix comment, for tk1 we build a gles2 and a gl versionMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29meta-openembedded layer bbappendsMax Krummenacher
Move the appends on recipe's which are not in an essential required layer into a target layer specific directory and add them only if said layer is active in build/conf/bblayers.conf. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
