The binary drivers in linux-driver-package have dependencies on
gstreamer's base plugins.
Add them to DEPENDS, so that they are available during do_rootfs.
Addresses:
Collected errors:
* calculate_dependencies_for: Cannot satisfy the following dependencies for linux-driver-package:
* libgstvideo-0.10-0 (>= 0.10.36)
* libgstinterfaces-0.10-0 (>= 0.10.36)
* libgstpbutils-0.10-0 (>= 0.10.36)
* libgstvideo-0.10-0 (>= 0.10.36) *
* opkg_solver_install: Cannot install package linux-driver-package.
Move current gstreamer1.0 base libgstomx to libgstomx1
and add libgstomx with gstreamer-0.10 support for TK1
With recipe specific sysroot configure fails when libxfont is
not a dependency.
The read_ahead configuration is now set using udev. The script run from udev
was added to meta-toradex-bsp-common, since it applies to all modules with
eMMC.
Signed-off-by: Leonardo Graboski Veiga <leogveiga@gmail.com>
| Collected errors:
| * check_data_file_clashes: Package linux-driver-package-dev wants to install file
| .../sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/libGL.so
| But that file is already provided by package * libgl-mesa-dev
d.getVar()'s expand parameter is no longer optional and a python exception is
raised in do_unpack.
While at it, do not redefine the location of S and skip QA warnings caused by
the already stripped binary drivers and unusual Nvidia library location.
the already stripped binary drivers.
Migrate Nvidia init scripts to systemd.
With only systemd in DISTRO_FEATURES those sysmlinks no longer are created
with the update_rc bbclass.
The 1.17 Xserver does not (yet) support a packageconfig set as default in
xserver-xorg.inc.
Make the 1.17.2 only used for tk1 machines.
With the update xserver-xorg update to 1.18 and 'xf86-input-evdev:
Upgrade 2.9.2 -> 2.10.0' this file is provided by the evdev recipe.
So when using an older xserver-xorg don't deploy the file.
The gstreamer based package rdepend on gstreamer components so add
the relevant RDEPEND for these packages.
Silence warnings which can not be avoided with the binary distibuted files.
While at it move the bbappend and xorg.conf under jetson-tk1 so that
one only needs meta-jetson-tk1 when one builds for tk1.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
