Move installing of the driver package from machine firmware to the
XSERVER variable where it belongs.
This allows an image without X11 to not pull in unnedded userspace drivers.
For the recipes listed in EXTRA_IMAGEDEPENDS, bitbake would create a
dependency as:
| image_pn:do_image_complete -> imagedepends_pn:do_populate_sysroot
but we actually need a image task depend on the deploy tasks of
EXTRA_IMAGEDEPENDS recipes, setting EXTRA_IMAGEDEPENDS would not help
with that, so drop it, use WKS_FILE_DEPENDS instead.
We also need drop "IMAGE_BOOT_FILES +=", that would override
"WKS_FILE_DEPENDS ?=".
Signed-off-by: Ming Liu <ming.liu@toradex.com>
This depends on and deploys the distro boot script provided
by u-boot-distro-boot.
The bmap file allows to use the bmap tools to flash the wic image.
Using bmap is faster than using dd.
bmaptool copy --bmap <image>.wic.bmap <image>.wic.gz /dev/sdX
This allows to use u-boot-fw-utils in image recipes.
Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
While at it append -tk1 to PN to have a name different from the u-boot recipe
name for our NXP based SoM and set the prefered provider accordingly.
Provide the MACHINE_NAME variable which can be e.g. used as part of the
image name.
linux-driver-package* contains more than just X11 components.
As we dropped meta-angstrom, do not prefer psplash-angstrom anymore.
SERIAL_CONSOLE has been deprecated for a while now
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply too high. Keep using the rocko based 2.8 BSP for these machines.
The kernel class now sets RDEPENDS_${KERNEL_PACKAGE_NAME}-base so this include
needs to do the same, otherwise bitbake emits a warning and the kernel isn't
removed.
Currently only imx and vybrid automatically generate wic images. This
functionality is useful e.g. for booting from SD cards. Add wic image
generation in tegra modules.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Add Toradex Easy Installer image class and the image type with all
required variables to the Apalis T30 machine config.
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
Move UBOOT_BINARY, UBOOT_IMAGE and UBOOT_SYMLINK definitions to machine
configuration re-used by the Toradex Easy Installer U-Boot recipe.
Change the compression method for the rootfs from bz2 to xz.
This unifies the Toradex bsp with the same change done to NXP
based machines when we added the Toradex Easy Installer.
While at it also update the comment in recipes-graphics/mesa/mesa_%.bbappend.
In our images this has been done during do_rootfs and friends,
do it the oe-core way.
While at it clean-up and unify with other Toradex layers.
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
Unsetting KEEPUIMAGE requests that vmlinux is built and later manually
packed into a uImage.
The resulting uImage in morty now packeges a gz compressed kernel in favour of
the uImage compression. Our U-Boot is not configured to boot such a uImage.
So keep the default setting for KEEPUIMAGE.
However the deploy logic for device tree-files can not cope with this
and prefixes the device-tree files with vmlinux and not uImage as expected.
The base_contains function is deprecated and we ought to use
bb.utils.contains instead.
This is only used for choosing a custom logo size. Not needed in our
use case.
meta-openembedded/meta-oe/recipes-kernel/linux/linux.inc
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Change DEFAULTTUNE in machine configurations to Thumb-2.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
Include the NVIDIA binaries as soon as X11 is in distribution
features. This allows to use the hardware accelerated X11 DDX
driver "tegra" even when OpenGL is not selected by the image.
Consolidate Tegra specific machine configuration in a common
tegra-base.inc file.
Since the boot loader requires a kernel-image in /boot, add the
kernel-image to MACHINE_ESSENTIAL_EXTRA_RDEPENDS. This allows to
boot images which do not select packagegroup-boot by default such
as the Poky reference distribution images.
Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
