With recipe specific sysroot configure fails when libxfont is
not a dependency.
- adapt to the changes introduced with recipe specific sysroots
- tegrarcm can now also be built for a target
- tegrarcm can now also be built for nativesdk
- License has changed
- For target builds a versioned shared object is now created
While at it clean-up the calls to make.
This prevents the OE warning 'No GNU_HASH in the elf binary'.
While at it also update the comment in recipes-graphics/mesa/mesa_%.bbappend.
While at it also rename it from trdx-k20-fw to tdx-k20-fw.
Use INSANE_SKIP_<package> in place of the unusual WARN_QA_remove.
Use the new version variables plus the git hash. Inspired by
meta-freescale/classes/fsl-u-boot-localversion.bbclass.
The hdmi.sh script, triggered by udev, export the DISPLAY environment
variable and uses the Xauthority configuration file to enable xrandr to
run.
Also restarts LXDE after xrandr, adjusting the taskbar length to the new
display width.
Signed-off-by: Leonardo Graboski Veiga <leogveiga@gmail.com>
The read_ahead configuration is now set using udev. The script run from udev
was added to meta-toradex-bsp-common, since it applies to all modules with
eMMC.
eMMC.
- add the original xserver-xorg.inc which matched the 1.14.4 recipe as the
current one is no longer compatible with the older xserver.
- renamed to xserver-xorg-1.14.7.inc
- merge in OE specific changes from current xserver-xorg,inc.
- merge bbappend into the bb file, we are the only user of this recipe.
- set the compatible machine to SOC-Family rather than specific machines.
reorder assignments to be similar between tegra, tegra124, tegra124m
remove unneeded COMPATIBLE_MACHINE assignement.
The 'rdepending' packages are picked up automatically by the
buildsystem.
| Collected errors:
| * check_data_file_clashes: Package linux-driver-package-dev wants to install file
| .../sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/libGL.so
| But that file is already provided by package * libgl-mesa-dev
In our images this has been done during do_rootfs and friends,
do it the oe-core way.
Use the d.*Var variant instead.
While at it clean-up and unify with other Toradex layers.
pushd and popd are not posix compliant.
The old fix was no longer working after the update to gtk+3.
Add a similar fix for gtk+3 as the one we used with gtk+2.
While at it do it in a two step process, only if the original call
does return with 'NULL' use a less specific gdk call.
d.getVar()'s expand parameter is no longer optional and a python exception is
raised in do_unpack.
While at it, do not redefine the location of S and skip QA warnings caused by
the already stripped binary drivers and unusual Nvidia library location.
the already stripped binary drivers.
This reverts commit 5b5356a28d06ccb8806310b4133b345fae178aba.
The commit duplicated the bbappend which now lives in
jetson-tk1/recipes-bsp/binary-drivers. Thus remove the duplicated
file.
When no resistive touch panel is connected spurious events
were generated.
