Generate cbootimage already during build as required for Toradex Easy
Installer BSP package.
The binary drivers in linux-driver-package have dependencies on
gstreamer's base plugins.
Add them to DEPENDS, so that they are available during do_rootfs.
Addresses:
Collected errors:
* calculate_dependencies_for: Cannot satisfy the following dependencies for linux-driver-package:
* libgstvideo-0.10-0 (>= 0.10.36)
* libgstinterfaces-0.10-0 (>= 0.10.36)
* libgstpbutils-0.10-0 (>= 0.10.36)
* libgstvideo-0.10-0 (>= 0.10.36) *
* opkg_solver_install: Cannot install package linux-driver-package.
Update to latest Linux LTS 4.9.52, add V1.2 hardware support and prepare
for optional CI top of linux-stable 4.9.y branch builds.
The binary drivers in tdx-nv-binaries have dependencies on gstreamer
et. al.
Addresses:
| Collected errors:
| * calculate_dependencies_for: Cannot satisfy the following dependencies for packagegroup-basic:
| * gstreamer (>= 0.10.36) * libgstaudio-0.10-0 (>= 0.10.36) * libgstinterfaces-0.10-0 (>= 0.10.36) * libgstvideo-0.10-0 (>= 0.10.36) * libxv1 (>= 1.0.10) *
| * opkg_solver_install: Cannot install package packagegroup-basic.
| * calculate_dependencies_for: Cannot satisfy the following dependencies for tdx-nv-binaries-nv-gstapps:
| * gstreamer (>= 0.10.36) * libgstinterfaces-0.10-0 (>= 0.10.36) *
| * opkg_solver_install: Cannot install package tdx-nv-binaries-nv-gstapps.
Depending on the availability of libgstphotography configure picks
up the dependency and builds for it. Change configure to never
build against it.
This addresses builds where libgstomx is taken from sstate but
libgstphotography is not available due to other dependencies.
| Collected errors:
| * calculate_dependencies_for: Cannot satisfy the following dependencies for libgstomx:
| * libgstphotography-0.10-23 (>= 0.10.23) *
| * opkg_solver_install: Cannot install package libgstomx.
Change the compression method for the rootfs from bz2 to xz.
This unifies the Toradex bsp with the same change done to NXP
based machines when we added the Toradex Easy Installer.
Move current gstreamer1.0 base libgstomx to libgstomx1
and add libgstomx with gstreamer-0.10 support for TK1
Prepare for snapd integration.
With recipe specific sysroot configure fails when libxfont is
not a dependency.
- adapt to the changes introduced with recipe specific sysroots
- tegrarcm can now also be built for a target
- tegrarcm can now also be built for nativesdk
- License has changed
- For target builds a versioned shared object is now created
While at it clean-up the calls to make.
This prevents the OE warning 'No GNU_HASH in the elf binary'.
While at it also update the comment in recipes-graphics/mesa/mesa_%.bbappend.
While at it also rename it from trdx-k20-fw to tdx-k20-fw.
Use INSANE_SKIP_<package> in place of the unusual WARN_QA_remove.
Use the new version variables plus the git hash. Inspired by
meta-freescale/classes/fsl-u-boot-localversion.bbclass.
The hdmi.sh script, triggered by udev, export the DISPLAY environment
variable and uses the Xauthority configuration file to enable xrandr to
run.
Also restarts LXDE after xrandr, adjusting the taskbar length to the new
display width.
Signed-off-by: Leonardo Graboski Veiga <leogveiga@gmail.com>
The read_ahead configuration is now set using udev. The script run from udev
was added to meta-toradex-bsp-common, since it applies to all modules with
eMMC.
eMMC.
- add the original xserver-xorg.inc which matched the 1.14.4 recipe as the
current one is no longer compatible with the older xserver.
- renamed to xserver-xorg-1.14.7.inc
- merge in OE specific changes from current xserver-xorg,inc.
- merge bbappend into the bb file, we are the only user of this recipe.
- set the compatible machine to SOC-Family rather than specific machines.
reorder assignments to be similar between tegra, tegra124, tegra124m
remove unneeded COMPATIBLE_MACHINE assignement.
