Related-to: ELB-4182
Basically, as per the following commit from the
toradex_4.9-2.3.x-imx branch on git://git.toradex.com/linux-toradex.git
57229263ff652d8f069203f6cfc8e8dc39fc6596
ARM: colibri-im6ull: enable on-module bluetooth
Related-to: ELB-2767
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Update linux-toradex-rt_4.9-2.3.x to patch-4.9.220-rt143.
Update linux-toradex-rt_4.4 to patch-4.4.220-rt197.
toradex_vf_4.4-next branch on git://git.toradex.com/linux-toradex.git
25e7f6f94e42b16a6d5298122e1e4dee0e6bc5b6
colibri_vf_defconfig: add support of backports-5.4
Related-to: ELB-2724
certs/Makefile uses openssl to generate cerificates.
Add openssl-native dependency fixes the building error [1].
[1]
/bin/sh: 1:
/bin/sh: 1: openssl: not found
openssl: not found
/oe-core/build/tmp-glibc/work-shared/apalis-imx6/kernel-source/certs/Makefile:48: recipe for target 'certs/signing_key.pem' failed
make[3]: *** [certs/signing_key.pem] Error 127
26e8afd3bb1614a04e11a75fff824b2ab7f6c4d6
apalis/colibri_imx6_defconfig: re-order kernel configurations
7eca4e0269d10cf9631eb66630e75109a067547d
apalis/colibri imx6/7/ull: defconfig: Add nf_filter
8a6d56b0d9d096b97ef5d4d39a31fb9b00e39174
ARM: apalis/colibri-imx6/7/6ull: enable options required for backports
61b327f5600e76de0c9c42c780fcfb5d4b41b5a8
ARM: apalis/colibri-imx6/7/6ull: disable wireless drivers
On Fedora 26 gstreamer build failed previously in not finding the
correct *.so files. This directive helps in finding them.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Update to L4.9.123-2.3.0_8mm_ga release.
Update to branch toradex_4.9-2.3.x-imx based on 4.9-2.3.x-imx branch of
linux-fslc currently re-based to 4.9.144.
Actually make use of them various upgrades.
As per meta-freescale commit 927b31771dab ("xf86-video-imx-vivante: Remove fb
from name") this recipe got renamed and should no longer be used!
Pulled from 6c1f35fdd5a762a3376c314dd36c564858d20cdb on
meta-freescale/master.
Pulled from 0f8d9894f9d7af73411883707c262911537f2695 on
Pulled from f1e26d9de04bc80aeff8e8e31e2f0862f0556419 on
We do want it for epxp support, however, later versions moved from using
kernel-headers to libdrm includes.
Signed-off-by: Carlos Rafael Giani <crg7475@mailbox.org>
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
(cherry picked from commit 076b00fcd36d30171e6f50ac0c4abd7e4ac82e1d on
meta-freescale/master)
Update to L4.9.123-2.3.0_8mm_ga release:
gstreamer1.0-plugins-imx update from 0.13.0 to git 963aea60b1
imx-gst1.0-plugin update from 4.3.4 to 4.4.2
gstreamer1.0 update to 476c63185e6864f82e938247235e7ad8ad20af4b on
Pulled from 30d8e9ad3aea13417a73979215412b3df9871d6d on
Pulled from 72dac5cac22806baf44610519e8091b528c79218 on
Pulled from c9bb48f2887667c59b8353e7ab5e44e41324375a on
Pulled from 1594c64aa5d51a0c97835f6548215fb0b48e0a34 on
Pulled from aac087e42024c290adf34d93ce57a3e8ace2c23f on
Pulled from 17a43b80cee64ef1cf25ae1f1ce8bc81596fb91d on
Pulled from 86000786e5d86bf0fc9f919b74f17a1d825d6351 on
Add support for new SKU 0045 WiFi non-IT variant.
Device trees for the carrier board Aster are now available, deploy
them.
This is required since meta-freescale commit a4158e3425a7
("gstreamer1.0: Set DEFAULT_PREFERENCE as -1 to imx version") et. al.
and is analogous to meta-freescale-distro commit 29e7a3d322c7
("fsl-base.inc: Set PREFERRED_VERSION for Gstreamer to use i.MX Version"
Colibri iMX6ULL and Colibri iMX7 were added as according to the i.MX
Reference Manual L4.1.15_2.1.0-ga they at least could profit from the
Pixel Pipeline (PxP) DMA-ENGINE driver.
When building the SDK one gets a warning and most -dev packages do not
get installed.
| * Problem 1/1:
| * - package libgl-imx-dev-1:6.2.2.p0-aarch32-r0.armv7at2hf-neon-mx6q
dl requires libgl-mesa-dev, but none of the providers can be installed
The opkg file for libgl-mesa-dev exist but somehow is not considered for
installation. Not depending on it at least installs the other -dev
packages.
See also:
https://www.toradex.com/community/questions/19849/bitbake-do-rootfs-failed-with-rocko-and-dev-pkgs-i.html
Enforcing to build 32-bit binaries for native and portions thereof
using -m32 in EXTRA_OEMAKE_class-native may lead to building errors.
Also, it seems it's time to move on from 32-bit compatibility.
Affected repositories:
meta-toradex-demos
meta-toradex-nxp
meta-toradex-tegra
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Adjust defconfigs for use with backports
While at it use consistently the .xz compressed rt-patch file.
The device tree got changed to use the simple card driver, so enable it
in the defconfig.
While at it remove the IMX_SGTL5000 driver now replaced by the simple card driver.
While at it remove the unused ESAI driver.
While at it remove the unused CS42XX8_I2C codec driver.
Add support for new SKU non-WiFi IT variant.
It wrongly assumed lib64 layout if building on 64-bit machine.
This i.MX specific version is based on v2.4.84
Signed-off-by: Yuqing Zhu <carol.zhu-3arQi8VN3Tc@public.gmane.org>
Pulled from meta-freescale mailing list.
This resp. a later version got recently pulled into the rocko branch of
meta-freescale.
This reverts commit 5faa79028eead21680d490a1b589a3875f966e0e.
The linux-toradex and linux-toradex-rt recipe adds a directory
with valid defconfigs to FILESEXTRAPATHS. Bitbake chooses the
first defconfig which it founds, which in that case is the one
from linux-toradex...
Include linux-toradex first, and then prepend the path from the
linux-toradex-rt recipe to make sure the defconfig for the -rt
kernel will be used.
However, in this scenario the PV variable can not be used since
linux-toradex_4.9-1.0.x.bb appends PV with image version and git
hash. Avoid using variables to avoid any ambiguity.
The string "header" refers to which imx header the utility should
try to use. Some binaries seem to have 2 headers, and header2
refers to the second.
Our binaries have only 1 header, but imx_usb seems to fall back in
that case. This might not be the case with newer imx_usb utilities.
Specifying just "header" is correct and works in all version of
imx_usb.
