path: root/conf
2020-03-12distro: set wayland/weston version for nxp 2.3.1 BSPVerdin-iMX8MM_Console-Image_3.0b4.254-20200421Colibri-iMX8X_Console-Image_3.0b4.254-20200421Colibri-iMX7_Console-Image_3.0b4.254-20200421Colibri-iMX7-eMMC_Console-Image_3.0b4.254-20200421Colibri-iMX6_Console-Image_3.0b4.254-20200421Colibri-iMX6ULL_Console-Image_3.0b4.254-20200421Apalis-iMX8_Console-Image_3.0b4.254-20200421Apalis-iMX8X_Console-Image_3.0b4.254-20200421Apalis-iMX6_Console-Image_3.0b4.254-20200421Apalis-TK1_Console-Image_3.0b4.254-20200421Apalis-TK1-Mainline_Console-Image_3.0b4.254-20200421Max Krummenacher
NXP's 2.3.1. BSP is based on the following version. wayland-protocols: "1.16.imx" weston: "5.0.0.imx" Related-to: ELB-2303 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-02-12distro: add -rt to the image base nameMax Krummenacher
Currently the generated image file names do not change with a change of the distro flavour. Related-to: ELB-1424 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-02-12tdx distros: provide a distro override with the distro nameMax Krummenacher
2020-01-06tdx-base.inc: increment thud version to 3.0b4Marcel Ziswiler
2019-10-01distros: provide a variable describing the distro flavourMax Krummenacher
This is used in generating the image name, so that one sees in the Toradex Easy Installer which is which. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-09-18tdx distros: add a distro which builds with the downstream rt kernelMax Krummenacher
This defines preempt-rt in distro overrides. The individual machine configuration then needs to choose the RT kernel flavour. While at it, unify comment. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-09-09tdx-base.inc: increment thud version to 3.0b3Marcel Ziswiler
2019-08-05layer.conf: support warriorColibri-iMX8X_Console-Image_3.0b2.65-20190830Colibri-iMX7_Console-Image_3.0b2.65-20190830Colibri-iMX6_Console-Image_3.0b2.65-20190830Colibri-iMX6ULL_Console-Image_3.0b2.65-20190830Apalis-iMX8_Console-Image_3.0b2.65-20190830Apalis-iMX6_Console-Image_3.0b2.65-20190830Apalis-TK1_Console-Image_3.0b2.65-20190830Apalis-TK1-Mainline_Console-Image_3.0b2.65-20190830Stefan Agner
The distro layer seems to work fine with newer OpenEmbedded releases, add warrior to supported series. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2019-06-17tdx-base.inc: increment thud version to 3.0b2Marcel Ziswiler
2019-06-02layer.conf: set BBFILE_PATTERN_IGNORE_EMPTYApalis-iMX8_Console-Image_3.0b1.40-20190612Ming Liu
This mutes a following QA warning: | WARNING: No bb files matched BBFILE_PATTERN_meta-toradex-distro | '^/mnt/toradex/toradex-build/build/../layers/meta-toradex-distro/' Signed-off-by: Ming Liu <liu.ming50@gmail.com>
2019-05-22tdx-base.inc: gstreamer: set preferred version for use-mainline-bspMax Krummenacher
Using python to conditionally set PREFERRED_VERSION_xxx does work, however bitbake evaluates the value of PREFERRED_VERSION_xxx before set in the python function. Reverting the conditional assignment in favour of a hard coded upstream value. fixes: 1e400c68e Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-20tdx-base.inc: gstreamer: only set imx override if use-mainline-bsp is not usedMax Krummenacher
The recipes for gstreamer* with version 1.14.imx set compatible version to mx6, mx7, mx8. So for machines which use use-mainline-bsp we get a lot of OE warnings during build, e.g.: | NOTE: preferred version 1.14.imx of gstreamer1.0 not available (for item gstreamer1.0) | NOTE: versions of gstreamer1.0 available: 1.14.4 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-03tdx-base.inc: fix commentMax Krummenacher
build is actually a file not a directory. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-25conf/layer.conf: decrease layer priority to 21Max Krummenacher
2019-04-18distro: add tdx-xwayland distroMax Krummenacher
2019-04-18distro: use gstreamer1.0 imx version for imx SoCMax Krummenacher
2019-04-09tdx-base.inc: set hostname by defaultMax Krummenacher
If a derived distro does not want /etc/hostname then that should be added for that distro only. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06populate inital distroMax Krummenacher
Only adds a tdx-x11 distro. Additional flavours to follow. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
