The distro layer seems to work fine with newer OpenEmbedded releases,
add warrior to supported series.
This mutes a following QA warning:
| WARNING: No bb files matched BBFILE_PATTERN_meta-toradex-distro
| '^/mnt/toradex/toradex-build/build/../layers/meta-toradex-distro/'
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Using python to conditionally set PREFERRED_VERSION_xxx does work, however
bitbake evaluates the value of PREFERRED_VERSION_xxx before set in the
python function.
Reverting the conditional assignment in favour of a hard coded upstream value.
fixes: 1e400c68e
The recipes for gstreamer* with version 1.14.imx set compatible version to
mx6, mx7, mx8. So for machines which use use-mainline-bsp we get a lot of
OE warnings during build, e.g.:
| NOTE: preferred version 1.14.imx of gstreamer1.0 not available (for item gstreamer1.0)
| NOTE: versions of gstreamer1.0 available: 1.14.4
build is actually a file not a directory.
If a derived distro does not want /etc/hostname then that should be added
for that distro only.
Only adds a tdx-x11 distro. Additional flavours to follow.
