2021-06-05 | layer.conf: add honister to compat layer | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2021-03-23 | layer.conf: add hardknott, drop dunfell in compat layer | Max Krummenacher | |
2020-10-17 | conf: Make layer compatible only with dunfell and gatesgarth | Max Krummenacher | |
2020-03-21 | layer.conf: add dunfell, drop warrior in compat layer | Max Krummenacher | |
2019-10-23 | layer.conf: add zeus, drop thud from compatible layers | Max Krummenacher | |
2019-08-05 | layer.conf: support warriorColibri-iMX8X_Console-Image_3.0b2.65-20190830Colibri-iMX7_Console-Image_3.0b2.65-20190830Colibri-iMX6_Console-Image_3.0b2.65-20190830Colibri-iMX6ULL_Console-Image_3.0b2.65-20190830Apalis-iMX8_Console-Image_3.0b2.65-20190830Apalis-iMX6_Console-Image_3.0b2.65-20190830Apalis-TK1_Console-Image_3.0b2.65-20190830Apalis-TK1-Mainline_Console-Image_3.0b2.65-20190830 | Stefan Agner | |
The distro layer seems to work fine with newer OpenEmbedded releases, add warrior to supported series. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> | |||
2019-06-02 | layer.conf: set BBFILE_PATTERN_IGNORE_EMPTYApalis-iMX8_Console-Image_3.0b1.40-20190612 | Ming Liu | |
This mutes a following QA warning: | WARNING: No bb files matched BBFILE_PATTERN_meta-toradex-distro | '^/mnt/toradex/toradex-build/build/../layers/meta-toradex-distro/' Signed-off-by: Ming Liu <liu.ming50@gmail.com> | |||
2019-04-25 | conf/layer.conf: decrease layer priority to 21 | Max Krummenacher | |
2019-03-06 | populate inital distro | Max Krummenacher | |
Only adds a tdx-x11 distro. Additional flavours to follow. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> |
