2021-08-14 | layer: convert to new override syntax | Max Krummenacher | |
This is the result of automated script (0.9.3) conversion: ../openembedded-core/scripts/contrib/convert-overrides.py . +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2020-02-13 | distro: add -rt to the image base name | Max Krummenacher | |
Currently the generated image file names do not change with a change of the distro flavour. Related-to: ELB-1424 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit ab0bca582337022fbc6763ce43013ce3baa96208) | |||
2019-10-01 | distros: provide a variable describing the distro flavour | Max Krummenacher | |
This is used in generating the image name, so that one sees in the Toradex Easy Installer which is which. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2019-09-18 | tdx distros: add a distro which builds with the downstream rt kernel | Max Krummenacher | |
This defines preempt-rt in distro overrides. The individual machine configuration then needs to choose the RT kernel flavour. While at it, unify comment. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> |
