2021-08-14 | layer: convert to new override syntax | Max Krummenacher | |
This is the result of automated script (0.9.3) conversion: ../openembedded-core/scripts/contrib/convert-overrides.py . +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2020-12-08 | tdx distros: add x11 to image filename and descriptions | Max Krummenacher | |
So far the graphical backend (X11 / Wayland) did not show in the created image names or the Toradex Easy Installer meta data at all. As we now build by default only Wayland, leave those alone. If one builds for X11 then add this to the file name and the descriptive meta data. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2020-06-18 | distros: define imx default bsp | Max Krummenacher | |
meta-freescale handles use-mainline-bsp in the common imx-base.inc file. Follow that change. While at it, simplify the upstream-rt distros by including the corresponding upstream distro. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2020-03-21 | tdx distros: add non-rt and rt distros which use an upstream kernel | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 32d4cdf84966fd20d7dcd58c25d574f3e1ff947f) |
