This is the result of automated script (0.9.3) conversion:
../openembedded-core/scripts/contrib/convert-overrides.py .
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
converting the metadata to use ":" as the override character instead of "_".
So far the graphical backend (X11 / Wayland) did not show in the created
image names or the Toradex Easy Installer meta data at all.
As we now build by default only Wayland, leave those alone. If one builds
for X11 then add this to the file name and the descriptive meta data.
'upstream' has already been appended in tdx-xwayland-upstream.conf.
Don't add a second one. I.e. don't create an image file name like this:
Apalis-iMX6_Reference-Minimal-Image-upstream-rt-upstream-Tezi_5.0.0-devel-20200817071112+build.0
meta-freescale handles use-mainline-bsp in the common imx-base.inc
file. Follow that change.
While at it, simplify the upstream-rt distros by including the
corresponding upstream distro.
(cherry picked from commit 32d4cdf84966fd20d7dcd58c25d574f3e1ff947f)
