path: root/buildconf
2021-08-16buildconf/local.conf: increase local.conf version identifierMax Krummenacher
With the override syntax change oe bumped the needed version. See commit 5452f1ba33 ("local.conf.sample: Bump version so users update their config") Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-08-14layer: convert to new override syntaxMax Krummenacher
This is the result of automated script (0.9.3) conversion: ../openembedded-core/scripts/contrib/convert-overrides.py . +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-05-24local.conf: stop including image-mklibs.bbclassMax Krummenacher
Openembedded core no longer provides the class. Remove it. See commit 908df863b4 ("mklibs: remove recipes and class") Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-05-24local.conf: add toradex-sanity to INHERITMing Liu
To involve in basic sanity check for Toradex builds. Related-to: ELB-3944 Signed-off-by: Ming Liu <ming.liu@toradex.com> (cherry picked from commit a12eef0d00f2dce08e65ac3b70075a21abc5c5dc)
2021-03-23buildconf:local.conf: support fitimageMing Liu
It's by default disabled, the end users could choose to enable them by uncommenting two lines. Related-to: TOR-1700 Signed-off-by: Ming Liu <ming.liu@toradex.com> (cherry picked from commit ff7025a26e13326eb12444fb853de655629378e0)
2020-09-16local.conf: use xwayland as the default in the sample local.confMax Krummenacher
Related-to: ELB-2303 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 1e0d10b2851ac455618ab7e4c7db86c9ad1227a0)
2020-07-31buildconf: export: change targets to new image namesPhilippe Schenker
2020-07-23bblayers.conf: add meta-qt5 layerPhilippe Schenker
Related-to: ELB-2838 Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2020-06-18local.conf: correct confusing commentMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 276c966a04bbe4d19866becb3b8fc147d1079049)
2020-06-01apalis-tk1-mainline: drop machineMax Krummenacher
The downstream kernel gets to old to be used with the new zeus userspace components. Reuse the apalis-tk1 machine name to build a mainline kernel and drop the apalis-tk1-mainline machine. Related-to: ELB-2733 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 7f8cd66bb84f32c3b7dd4eea95ba9482786770c0)
2020-06-01buildconf: export: Add use-head-next also on repo 2.5Philippe Schenker
Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> (cherry picked from commit adb62ac9dfeed9827e0a706a5c2c2a64ebb95b06)
2020-06-01buildconf: epxort: set use-head-next on integration branch by defaultPhilippe Schenker
This addition checks if one is using the integration branch with repo if that is true it will automatically append the correct use-head-next setting. If this is for whatever reason not set it will tell the user to not forget setting use-head-next on integration branch. Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> (cherry picked from commit 045a6a34c51a436e864267f60501702ad6fdbcea)
2020-06-01buildconf: export: add support for zshPhilippe Schenker
zsh has which built-in. Therefore calling which echo is resulting in something unexpected: $ which echo echo: shell built-in command use $(env which echo), that is using a which command from the PATH variable. Also use $() instead of the deprecated ``. Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> (cherry picked from commit a4fa7bb1fb198fac82db91576994c98fc1014c71)
2020-02-13local.conf: sync with oe-core sampleMax Krummenacher
The 'Parallelism Options' are now set in bitbake.conf to a sensible default. Some options are now set with ?= to allow for easier overrides. A lot of trailing whitspace has been removed. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-01-07bblayers.conf: drop meta-qt5 and meta-qt5-extraMax Krummenacher
The dropped lxqt-image and qt5-x11-image were the only users of meta-qt5 and meta-qt5-extra. Remove those layers from our sample bblayers.conf. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-01-07bblayers.conf: drop meta-browser and meta-lxdeMax Krummenacher
The dropped lxde-image was the only user of meta-browser and meta-lxde. Remove those layers from our sample bblayer.conf. This also allows to drop meta-clang and meta-rust which are required only by meta-browser. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-12-07local.conf: add verdin-imx8mmMax Krummenacher
Add the new machine now available from meta-toradex-nxp. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-11-04bblayers.conf: add meta-clangMax Krummenacher
meta-browser now depends on meta-clang. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-09-30local.conf: add apalis-imx8xMing Liu
Since apalis-imx8x has been supported in meta-toradex-nxp layer, add it into local.conf. Signed-off-by: Ming Liu <ming.liu@toradex.com>
2019-09-09local.conf: add apalis-imx8/colibri-imx8x machinesMing Liu
2019-05-08bblayers.conf: drop parsing the qt4 layerMax Krummenacher
Qt 4 was first released in 2005 and has been unsupported since 2015. Drop it from what we regularly install. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-25local.conf: build i.mx8 machines with tdx-xwayland distroMax Krummenacher
NXP dropped X11 support for i.MX8 and i.MX8X. Thus build our images with the tdx-xwayland distro configuration. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-23colibri-vf: drop machineMax Krummenacher
We decided we won't do a BSP 3.0 for Vybrid. For new designs we recommend ULL now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-23local.conf: drop image_fstypes settingMax Krummenacher
There is a resonable default in bitbake.conf. For all our machines it is also set explicitely so there is no need to carry this in local.conf. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-07local.conf: change deploy/download/sstate directoriesMax Krummenacher
Move the DEPLOY_DIR directory to be inside the build directory. Using the same layer metadata to create two independent build directories (e.g. for two builds of the same machine but with different kernels) now has the deploy directory name no longer clash. Move DL_DIR and SSTATE_DIR to the root of the oe installation. This then automatically shares downloads and sstate between different build directories. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06buildconf: moved here from meta-toradex-demoMax Krummenacher
Also adapted to use the now available tdx-x11 distro. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
