Use separate variables for version components. This is useful to form
the new OSTree branch names which use the major version only.
Related-to: TOR-1107
Define PREFERRED_PROVIDER_virtual/dtb to device-tree-overlays.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
The downstream kernel gets to old to be used with the new zeus
userspace components. Reuse the apalis-tk1 machine name to build
a mainline kernel and drop the apalis-tk1-mainline machine.
Related-to: ELB-2733
NXP's 2.3.1. BSP is based on the following version.
wayland-protocols: "1.17.imx"
weston: "5.0.0.imx"
Related-to: ELB-2303
(cherry picked from commit be3bebbc165727418f261d29bd75dd413527fd97)
'DISTRO' is in DISTROOVERRIDES by default, we should not use "=" to
override that when adding 'tdx' to DISTROOVERRIDES, use ".=" to append
to it.
With the above change, we do not need to append 'tdx-x11' and
'tdx-xwayland' to DISTROOVERRIDES, drop them.
It should be moved to meta-toradex-torizon layer.
This addition checks if one is using the integration branch with repo
if that is true it will automatically append the correct use-head-next
setting. If this is for whatever reason not set it will tell the user
to not forget setting use-head-next on integration branch.
zsh has which built-in. Therefore calling which echo is resulting
in something unexpected:
$ which echo
echo: shell built-in command
use $(env which echo), that is using a which command from the PATH
variable. Also use $() instead of the deprecated ``.
Currently the generated image file names do not change with a change
of the distro flavour.
Related-to: ELB-1424
The dropped lxqt-image and qt5-x11-image were the only users of meta-qt5
and meta-qt5-extra.
Remove those layers from our sample bblayers.conf.
The dropped lxde-image was the only user of meta-browser and meta-lxde.
Remove those layers from our sample bblayer.conf.
This also allows to drop meta-clang and meta-rust which are required
only by meta-browser.
Add TDX_VERSION which can be used by Toradex customized software
artifacts like U-Boot or the Linux kernel. This version number does
not contain a date timestamp to prevent unnecessary rebuilds. It is
assumed that the software artifact adds a build number (e.g. git
hash).
Implement new version number scheme. This has been tested recently in
meta-toradex-torizon and proven to work reliably. Lets move it to
meta-toradex-distro so all Toradex distribution can make use of it.
Add the new machine now available from meta-toradex-nxp.
Most of the desktop like images require polkit.
E.g. liblxqt depends on it.
meta-browser now depends on meta-clang.
oe-core commit ac83d22eb removed armv7a or armv7ve from the TUNE_FEATURES.
This made the python logic no longer kicking in and reverted to have
CPU specific package feeds.
This is used in generating the image name, so that one sees in the
Toradex Easy Installer which is which.
Since apalis-imx8x has been supported in meta-toradex-nxp layer, add it
into local.conf.
This defines preempt-rt in distro overrides. The individual machine
configuration then needs to choose the RT kernel flavour.
While at it, unify comment.
The distro layer seems to work fine with newer OpenEmbedded releases,
add warrior to supported series.
This mutes a following QA warning:
| WARNING: No bb files matched BBFILE_PATTERN_meta-toradex-distro
| '^/mnt/toradex/toradex-build/build/../layers/meta-toradex-distro/'
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Using python to conditionally set PREFERRED_VERSION_xxx does work, however
bitbake evaluates the value of PREFERRED_VERSION_xxx before set in the
python function.
Reverting the conditional assignment in favour of a hard coded upstream value.
fixes: 1e400c68e
The recipes for gstreamer* with version 1.14.imx set compatible version to
mx6, mx7, mx8. So for machines which use use-mainline-bsp we get a lot of
OE warnings during build, e.g.:
| NOTE: preferred version 1.14.imx of gstreamer1.0 not available (for item gstreamer1.0)
| NOTE: versions of gstreamer1.0 available: 1.14.4
Qt 4 was first released in 2005 and has been unsupported since 2015.
Drop it from what we regularly install.
build is actually a file not a directory.
NXP dropped X11 support for i.MX8 and i.MX8X.
Thus build our images with the tdx-xwayland distro configuration.
Thud next, new features, drop colibri-vf
See merge request rd/linux-bsp/meta-toradex-distro!2
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
There is a resonable default in bitbake.conf. For all our machines it is also
set explicitely so there is no need to carry this in local.conf.
If a derived distro does not want /etc/hostname then that should be added
for that distro only.
