2015-08-07 | icu: upgrade reduced icu data to version 54 | Max Krummenacher | |
2015-05-12 | florence: use oe standard download mirror for sourceforge | Max Krummenacher | |
2015-05-12 | opencv: add patches for libav 10.x API | Max Krummenacher | |
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-05-12 | i2ctools: don't install the perlscript and perl | Max Krummenacher | |
Mechanism changed to what the bb file now offers. | |||
2015-05-12 | icu: upgrade reduced icu data to version 53 | Max Krummenacher | |
While at it move version to % placeholder and use wildcards in receipe icu: use wildcard to be independent of version | |||
2015-03-31 | gnutls: remove bbappend | Max Krummenacher | |
gnutls recipe now detects pthread in configure task correctly. | |||
2015-03-31 | FILESEXTRAPATHS_prepend: add proper list separator | Max Krummenacher | |
2014-12-18 | mcc-pingpong: alter CFLAGS to use the actual kernel headers | Stefan Agner | |
To use the kernel interfaces required for mcc-pingpong we need the kernel headers of the actual kernel. Alter CFLAGS to add the kernel headers to the include path. | |||
2014-12-11 | consolekit: add systemd to DEPENDS if needed | Max Krummenacher | |
2014-08-04 | gnutls: hack to use libpthread | Max Krummenacher | |
gnutls use libgcrypt and should init gcrypt's mutex functionality but does not. This leads to asserts in libgcrypt: Ohhhh jeeee: Assertion `pool_is_locked' failed (random-csprng.c:615:mix_pool) This patch hacks autoconf to always use libpthread and thus initalizes libgcrypt with working mutex functions. | |||
2014-08-04 | libpcre: Use generic bbappend versioning | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-05-02 | mcc-pingpong: demo application for ping pong with Cortex M4 | Stefan Agner | |
2014-04-30 | icu: add break iterator support for webkitgtk | Stefan Agner | |
Webkitgtk needs break iterator support in order to work. This avoids segmentation fault when using Midori web browser. | |||
2014-04-04 | icu: update to match bb version | Max Krummenacher | |
2014-03-31 | icu: is machine specific for colibri-vf | Max Krummenacher | |
For colibri-vf we deploy icu only partly to save diskspace, so set the PACKAGE_ARCH for that machine. | |||
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-10-16 | icu: fix SRC_URI | Max Krummenacher | |
2013-10-11 | icu: replace database with minimzed version | Max Krummenacher | |
2013-10-09 | i2c-tools: don't install the perl scripts (and thus don't RDEPEND on perl) | Max Krummenacher | |
2013-09-22 | florence: RDEPEND on svg support to draw icon | Max Krummenacher | |
2013-09-22 | libfm: bbappend updated to 1.1 | Max Krummenacher | |
2013-09-22 | libpcre: bbappend update to 8.32 | Max Krummenacher | |
2013-04-02 | florence: fix garbled titlebar | Max Krummenacher | |
2013-02-06 | libfm: set lxterminal as the terminal application | Max Krummenacher | |
2012-10-18 | libvpx, version update in oe-core | Max Krummenacher | |
2012-08-27 | nautilus depends on gobject-introspection-native | Max Krummenacher | |
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image rename bbappend because coresponding bb does not exist |
