Resurrect from meta-openembedded/meta-efl.
Empty RDEPENDS are not needed, the others are automatically added
by the buildsystem.
As e.g. our Tegra modules are multihead capable and if HDMI is plugged
in while the xinput calibrator was run this led to the following error
message:
root@apalis-t30:~# xinput_calibrator_once.sh
Unknown option: 640x480
Fix this by just using the first detected heads geometry definition.
silence warning for hash-style not gnu
WARNING: unclutter-1.09-r0 ... No GNU_HASH in the elf binary: '...unclutter' [ldflags]
Fixes:
| ERROR: giblib-1.2.4-r0 do_populate_sysroot: QA Issue: giblib.pc failed sanity test (tmpdir) in path .../work/armv7at2hf-neon-angstrom-linux-gnueabi/giblib/1.2.4-r0/sysroot-destdir/usr/lib/pkgconfig [pkgconfig]
This bbappend is required by packages built with meta-lxde.
Thus move it were it belongs.
The evdev version provided by oe-core is in the meantime newer than
this backport, hence we can safely remove it.
The upstream server currently gives error 403.
$ wget http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
--2015-09-17 10:50:25-- http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
Resolving linuxbrit.co.uk (linuxbrit.co.uk)... 65.110.41.18
Connecting to linuxbrit.co.uk (linuxbrit.co.uk)|65.110.41.18|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2015-09-17 10:50:25 ERROR 403: Forbidden.
(cherry picked from commit 77e6a09a5afeab9f0d550b3319e134ec991f50cf)
gpu-viv-bin-mx6q -> imx-gpu-viv
with a bunch of subpackages.
PublicDomain is not known to OE
Neiter graphviz_2.32.0.bb graphviz_2.38.0.bb work with dizzy.
Uses python directory from build host.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
This is also done by the session manager effectively starting the
autostart items twice.
Remove xinput-calibrator systemd service since autostart is done
using /etc/xdg/autostart/xinput_calibrator.desktop.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
Two popular VNC clients:
- DirectVNC based on DirectFB (e.g. without X11)
- TightVNC based on X11
(cherry picked from commit ef4113208de357a5b8accd7610f8bf3230125a59)
If the xinput-calibrator.service is enabled but lxdm.service is disabled lxdm
was started anyway because of the requires dependency.
Replase Requires with Requisite to have xinput-calibrator.service fail instead.
(cherry picked from commit e34e6361ecaaa8b148d438d517761bdd084d1a32)
adds gpu-viv-bin-mx6q-libraries package which RDEPENDS only the
libraries but not the samples.
V2.7.3 crash when it receives multitouch events
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- make the menuentry behave as the one time calibration on first boot
- Unclutter hides your X mouse cursor when you do not need it
on first boot
