This reverts commit da1129748dbea46522269eb87a99502f12ed20e8.
With the revert of the systemd version in angstrom this bbappend
needs the revert too.
The upstream systemd recipe now uses meson to build systemd. Follow the
changed config syntax.
(cherry picked from commit 6632d136cada3ae3b4cecdf29c611101778da5d4)
On the Tegras not using NEON for memcpy resulted in higher memory bandwidth.
Let's verify this before forward porting the patch.
Introduce packagegroup which contains the dependencies required to
use the .NET Core runtime.
We rely on the init system to remount the root file system read-only,
which makes the mount flags for the rootfs in fstab relevant. Since
we run on flash drives minimize write cycles by disabling atime by
by default.
We found that having ACL enabled in systemd on a ubifs adversely
affects power cut resilience.
Currently systemd is unconditionally enabled in a systemd build.
Add a acl packageconfig option, but do not enable it.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
By default systemd utilities use escape sequences to produce colored
output. But systemd also uses less as a pager. The less command
provided in the Toradex demo images is provided by BusyBox, which
does not support color escape sequences. Disable colored output
altogether. This makes output of journalctl much more readable.
Commit 619d15b9a2c53eb8496c807f0f229f5cb192e9d7 in openembedded-core
moves the inputrc file from the base-files to the readline recipe.
Follow that move with our *.bbappend.
This fixes <HOME>, <END> not working as expected on a serial console.
oe-core included resize in their profile too.
Synchronize with the OE solution which already does the redirect.
Don't emit DNS/NTP/Router/Timezone servers addresses to the RNDIS client.
We expect RNDIS to be used as a service/debug interface to connect to
a module. For this we do not want to reconfigure the connecting device
with the modules setup.
avoid clash with systemd provided resolv.conf
Collected errors:
* check_data_file_clashes: Package systemd wants to install file ../resolv.conf
But that file is already provided by package base-files
The BSP should automount for all users.
The Demo Software Layers cares for RNDIS.
A meta-toolchain build or a build which does not use the angstrom distro
builds glibc_2.21 rather than glibc_linaro-2.20.
The patch to not use the slower memcpy implemented for NEON does not apply
cleanly for both versions of glibc.
This adds a bbappend for glibc_2.21 forcing memcpy_arm.
0001-memcpy-don-t-use-optimized-for-VFP-NEON-versions.patch applies
not to oe glibc_2.21
This reverts commit bd2d32bf3a8460c87849e75ad01e11450d8cda10.
Remove the backport, is part of fido.
Angstom Dizzy now uses systemd V218 so there is no need to build
a component seperately anymore.
This reverts commit 16b8b392ad048566729f30d7c3887d1bfdf21bd4.
This changes the minimum required Linux version from 3.7 back to 3.0.
[YOCTO #7409]
Signed-off-by: Jonathan Liu <net147@gmail.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
backported from openembedded-core,
commit 31163abc7bedd477c1aad10e6d1f47dbee194513
This reverts commit 3cf2edb10f5e8ac60db7ca2e71d1e754a177d08c.
recipes-core/systemd/systemd_%.bbappend
Since Connman is better suited for more advanced Wireless solutions,
we keep Connman for the main network configuration manager. However,
for the simple RNDIS debug/test configuration, Connman is not well
suited since Connman tries to maintain one connection only at any
given time.
This change enables networkd and adds a simple standard configuration
for USB/RNDIS network devices.
When the link goes down, the DHCP service has been disabled, while
there is no corresponding functionality which enables the service
when the link goes up again. This fix is taken from systemd 217.
This enables the resize command in Busybox. The command is useful
when using the serial console and a non-standard terminal sizes.
we don't want busybox syslog as we use the functionality of journalctl
meta-angstrom now overrides the effect of the patch and provides the
journald.conffile in full.
To override a setting either create the file with your settings in
meta-toradex/recipes-core/systemd/systemd/journald.conf or
edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
Patch pending in meta-angstrom
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
Add the fstrim utility to Colibri T30 image. The utility allows to
send trim commands to the underlaying flash translation layer, which
allows too free not used flash sectors and those improve wear-
leveling
