This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
Sources from TorizonCore and BSP are aggregated on new artifactory repository
https://artifacts.toradex.com/artifactory/tdxref-torizoncore-sources-frankfurt/
Use this new link plus $TDX_MAJOR to use the correct sources for the current
major version
(cherry picked from commit 709b72950c5406ef0e511fee7030b51fc8681e14)
Update the URL of Toradex mirrors to the V2.6 subfolder. Unfortunately
we missed that before doing the V2.6 release, hence most builds will
try to fetch sources from V2.5. Therefor we synchronized all sources
of V2.5 and V2.6 images into the V2.5 source folder and symlinked V2.6
to it.
follow
http://cgit.openembedded.org/openembedded-core/commit/meta/classes/mirrors.bbclass?id=9560d58596ceb50280b81296688883f3fca99aa6
This avoids:
WARNING: Invalid protocol (svk) in PREMIRRORS: svk://.*/.* http://sources.toradex.com/V2.5/
To download the sources mirrored on sources.toradex.com add
the Toradex mirror as pre-mirror.
remove the files copied from meta-fsl* for Colibri-VF V2.1
move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
remove when moving to dora branch
