Backports for mainline currently fails building but also kind of does
not make much sense. However some customers might need the firmware.
Follow Pinmuxing for Apalis TK1 V1.2 Hardware.
Do not provide an empty postinst function with exit 0.
Because of this update-alternatives has not been called and thus
openbox instead of lxsession becomes the alternative used for
/usr/bin/x-window-manager.
Firmware for the Wi-Fi module on the Colibri iMX6ULL.
Deploy the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT
and choose the write one to flash into its UBI partition.
This adds the backports usable for all modules unconditionally
and the ones usefull for Apalis (PCIe) specifically to all
Apalis machines.
With the move to backports we added firmware packages in the
backports section and kept in the unconditional part.
Remove one of them.
For Apalis TK1 Mainline we can use the generic script from the library.
Remove the script with a symlink.
For Apalis TK1 we now use a ext4 rootfs. Thus the genext3fs script
is no longer needed. Don't deploy it.
As several customers reported qtcreator imports that python module when debugging.
https://www.toradex.com/community/questions/11201/qt-creator-debugging-python-issue-colibri-imx7d.html
LM816 wifi dongle uses this fw.
With the space restricted NAND there is no space for a browser.
do_image makes some optimizations on the rootfs, they should make it
into an image.
This speeds up compressing the final bz2 image. For angstrom-lxde-image
on a 24 core CPU by about 30 seconds.
Ignore the tar return value. "file changed as we read it" may be reported
because wic is creating hardlinks of files in the rootfs.
See openembedded commit 402b4cffbb4c58cfee93db18192f2b218ee0ae35
This is for some time done in oe-core without any intervention:
meta/classes/rootfs-postcommands.bbclass
Add this in IMAGE_PREPROCESS so that all image types get this
change.
The only machine which did not install canutils is colibri-t30.
Install it in all images. iproute2 is pulled in from canutils so
remove its explicit installation.
While at it cleanup curl which is included unconditianallly and in
the machine specfic parts.
Use u-boot-nand.imx which has the 1kB padding expected by boot
ROM at the beginning so it can be easily written into raw NAND
flash.
Introduce packagegroup which contains the dependencies required to
use the .NET Core runtime.
The .NET Core framework recommends to use OpenSSL backend by
default, otherwise not all SSL/TLS functions of the framework
are available.
Do no longer hard-code conf_blk_offset now that we reliably determine
it in check_configblock.
Unfortunately as loadaddr is equal to fdt_addr_r on some modules and
equal to kernel_addr_r on others using it together with any of the
others may cause issues. Therefore no longer make use of loadaddr and
consistently use fdt_addr_r instead.
The config block check aka check_configblock may fail during update
depending on the size of the hardware area boot partition which may
lead to the config block not getting properly migrated or updated if
still using parts of the legacy update procedure. This patch fixes
this by iterating over various sizes.
Improve on the config block locations checked for migration from
WinCE/WEC. Now also takes vendor part of the Boot Configuration Table
aka BCT into account.
We might want not to support burn flash for new machines. Make it
optional by checking whether the machine specific directory exists.
The new machine colibri-imx7-emmc uses eMMC and hence the regular
u-boot.imx binary.
Add a trailing ';' to separate from commands appended later.
The library libunwind is a dependency for the .NET Core 2.0
runtime. Preinstall it in our standard images.
We rely on the init system to remount the root file system read-only,
which makes the mount flags for the rootfs in fstab relevant. Since
we run on flash drives minimize write cycles by disabling atime by
by default.
Use PV variable to define the image version. With that the Tezi
image class can use OpenEmbedded variables to get the image version.
If a dtb file has more than one dot the current logic fails.
e.g. 'device.tree.dtb' will be truncated at the first dot to 'device'
while it should be 'device.tree'.
Fix by removing awk in favour of letting basename also remove
the .dtb extension.
The README content was no longer applicable, change it to reflect
the current use of the files here.
Use ext4 by default for TK1 modules.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Use ext4 by default for iMX6 modules.
Deploy gstreamer-0.10 with nvidia TK1 support plugins.
Deploy Ixora V1.1 device tree for Apalis iMX6.
This adds the bmode_usb binary to the i.MX6 rootfs which allows to
set some i.MX6 registers so, that on the next reboot (not powercycle)
the i.MX6 starts in serial download mode (aka. recovery mode).
The eject binary is used by the libudisk2.
Without it e.g. pcmanfm shows an error message that eject could
not be found.
If an image creates a rootfs which is exactly a multiple of 64 MByte then
the scripts never detects that the last chunk has been read and
'run update' never completes.
Fix that by explicitely setting filesize to 0 when a file read fails.
