USB RNDIS support is getting deprecated, move USB Ethernet-over-USB
functionality to USB NCM, update libusbgx configuration accordingly.
Related-to: ELB-4923
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit dbc9d3d74c81387cafa292bf06bf7ae91f5c3640)
Add interface name support for NCM Feature Descriptors to libusbgx,
patch has been sent to libusbgx upstream:
https://github.com/linux-usb-gadgets/libusbgx/pull/73
This is needed to let NCM work on Windows systems, update git revision
to the latest master branch to be able to apply the patch.
(cherry picked from commit 3987d6249e2549bc036545b038b5c71c41a60336)
tdx-info is a shell script that makes it easy to get information from
Toradex's module (and potentially, any machine).
The script is capable of showing the following information: bootloader
(version, vendor, some variables), kernel (version, command line
arguments), distro, hostname, related to Toradex's hardware (module's
full name and version, serial number, Toradex's Product ID and
Revision), device tree (device trees available, device tree loaded,
device tree overlays available, device tree overlays enabled), devices
in /dev, kernel modules loaded.
tdx-info requires read access (write access as well when stated) to the
following files/folders: /proc/cmdline, /etc/os-release, /etc/issue,
/etc/hostname, /proc/device-tree/model, /proc/device-tree/serial-number,
/proc/device-tree/toradex,product-id,
/proc/device-tree/toradex,board-rev,
/proc/device-tree/chosen/u-boot,version, /boot, /boot/overlays,
/boot/overlays.txt, /dev, write access to the home of the current user
(/home/<username>) .
Examples of tdx-info usage on a Verdin iMX8M Plus running Reference
Minimal Image from Toradex's BSP 5.7
Software summary
Bootloader: U-Boot
Kernel version: 5.4.193-5.7.0+git.f78299297185 #1 SMP PREEMPT Mon Jul 11 14:42:03 UTC 2022
Kernel command line: root=PARTUUID=a406e573-02 ro rootwait console=tty1 console=ttymxc2,115200 consoleblank=0 earlycon
Distro name: NAME="TDX Wayland with XWayland"
Distro version: VERSION_ID=5.7.0-build.20
Hostname: verdin-imx8mp-06849036
For more details see https://github.com/toradex/tdx-info/blob/master/README.md
Signed-off-by: Henrique Garcia <henrique.garcia@toradex.com>
(cherry picked from commit 042bdd4004a3cd21422104324077a3ce34594bc9)
It's a deprecated recipe not used by Toradex any more, drop it.
Related-to: ELB-4553
Hard-coded device/host MAC addresses could conflict with board MAC
addresses.
Also uprev to the latest master commit.
Related-to: ELB-4538
Upon hot-plugging device (resp. un-plugging host) dwc3_gadget_init()
does nicely get executed. However, for an actual gadget to get started,
it also requires the libusbgx dance as well. Instead of only doing this
upon boot aka after multi-user.target (which is fine only if the device
is already there at boot), execute it after usb-gadget.target. This
ensures dwc3_gadget_start() gets executed also during hot-plugging.
(cherry picked from commit 4487e89561252487608e227d7077cb2b2d79f37c)
Toradex NXP layer could be used by other external projects, so we
should make sure Toradex specific changes dont impact them.
Use 'tdx' overrides to ensure Toradex specific changes only valid for
Toradex distros.
Related-to: ELB-3046
(cherry picked from commit 9400ee43d6b14fbea12a82a047056c8581ec9d70)
If grep does not find anything the return code is non zero and given
postinst scripts are being run with set -e that means the postinst
script fails! Fix this by directly using fgrep in the if condition
instead to properly continue the postinst script even in such case.
(cherry picked from commit 65233ec68d2f19fb36b085cb06ac57321976dcf7)
Since OE-Core commit 9379f80f48 ("license/insane: Show warning for
obsolete license usage"), LICENSE field not containing SPDX identifiers
are treated with WARNING.
An automated conversion using scripts/contrib/convert-spdx-licenses.py to
convert to use the standard SPDX license identifiers has been done on
the entire layer.
Github no longer allows a plain git protocol.
https://github.blog/2021-09-01-improving-git-protocol-security-github/#no-more-unauthenticated-git
(cherry picked from commit be4af472843c95236a1dcd4552233ba1aaabc346)
Rather than assuming the relevant kernel modules are loaded and
the configfs is mounted do that here explicitely.
Allow both commands to return with a non zero return code as the
module might already be loaded and the configfs already be mounted.
Prevents a warning in 'systemctl status usbg'. Strings in device tree
properties are null terminated.
sh[354]: /bin/sh: warning: command substitution: ignored null byte in input
jitterentropy is now added by kernel as well
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.
git/commit/?id=50ee7529ec4500c88f8664560770a7a1b65db72b, so it can
be disabled without any issue.
Related-to: TOR-1079
Signed-off-by: Naeem Khan <naeem.khan@toradex.com>
Ported from meta-toradex-torizon, commit 53fc29e ("rngd-tools:disable
jitterentropy to avoid high cpu usage at startup") plus follow up e2c6c9b.
Related-to: ELB-4133
(cherry picked from commit 5d3c5bedd77106c37c568fbc553e160b463bbb27)
Converted to now override style, '_' -> ':'.
To involve in the following fixes:
1ee53e4 Copy ether_addr structs to avoid union pointer alignment issues
4852080 Delete embedded copies of libtool m4 files
ccba65f Tell git which paths to ignore are directories
3a0f66a Tell git to ignore autotools cruft in the src functions subdirectory
37fcf90 Tell git to ignore generated usbg_version.h header
1e7161d Tell git to ignore the generated cmake config file
b9a5b9c Tell git to ignore the right generated pkg-config .pc file
e972b9e Document that the configfs Linux kernel module needs to be loaded
97b6477 Support printer function
ad378b4 Fix --without-libconfig segment fault on gadget-hid attr setting
67605a0 libusbgx: examples: gadget-vid-pid-remove: fix exit code on success
e0cdec8 Merge pull request #54 from mgrzeschik/gadget-vid-pid-remove
547a759 Merge pull request #55 from mgrzeschik/uvc
52aa5ed libusbgx: Add UVC support
852087a libusbgx: examples: gadget-vid-pid-remove: add dynamic vid pid support
af2292c Fix typo in comment
664b7e6 Added support for CMake projects macros
b5ad66e Fix #39 Compilation fails on gcc v8
283879d libusbgx: fix --without-libconfig build against glibc-2.28
45c14ef libusbgx: fix build with glibc-2.28 since <sys/sysmacros.h> is no more included by <sys/types.h>
6ffbb21 libusbgx: Fix doc build with new doxygen version
dccb4f1 libusbgx: Fix out of tree compilation
especially the fix for:
https://github.com/linux-usb-gadgets/libusbgx/issues/57
Related-to: TEI-924
(cherry picked from commit cd152fb6c9a932e0bc2857d5e51a8fdd6bf14319)
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
(cherry picked from commit 0aec0986a859ea7f0cb8f9aeb56aae9ce8786568)
It's ${PN}-examples rather than ${PN} should be set in
SYSTEMD_PACKAGES.
Also do some cleaning up:
- Drop deprecated NATIVE_SYSTEMD_SUPPORT.
- Drop ${systemd_unitdir}/system/usbg.service from FILES.
(cherry picked from commit 3966043524aa76454c96903af5e9f73f4cf750e3)
Remove the leftover from the old way of specifying postinst() which needs
execution on target.
Completes commit 6f2590ec6085 ("pkg_postinst: move to the ontarget syntax").
(cherry picked from commit 54e7ade0bcc771ebb85dbd915f0ad8f658a5b0a2)
The downstream kernel gets to old to be used with the new zeus
userspace components. Reuse the apalis-tk1 machine name to build
a mainline kernel and drop the apalis-tk1-mainline machine.
Related-to: ELB-2733
(cherry picked from commit bd9bbe90a379468c60f689c99c3940bfb4a4181d)
Add the product name at compile time so that we do not need to provide
slightly different copies of the file.
While at it set package arch to machine arch. The packages created are
machine specific due to the g1.schema file.
(cherry picked from commit 3fa96f28bb30643cac3b8a49d3abd7c976acb704)
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
(cherry picked from commit 0f57f7913867e70ec691eaf31d4a74dd0becb0d4)
These machines use an old Nvidia provided downstream kernel 3.1.10. They no
longer much the way more recent sysroot components, e.g. libc, xserver et. al.
The maintance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
Replace a bunch of += assignments with = .
Put all RDEPENDS into one statement.
Cleanup indent to the prefered OE 4 spaces per level.
The update is mostly bugfixing, notably:
This fixes a build error with glibc 2.28.
additionally:
Add support for UAC2 function
Update to latest git for imx6, imx7 and tegra support and integrate
automatic board configuration support.
Libsoc is currently built with no directly enabled board config
(we will wait until all configs are available). All available
configs are nonetheless included in the rootfs and can be
symlinked to /etc/libsoc.conf to enable them. The library can be
otherwise used with the Linux GPIO numbers.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Using "10#" to treat the product ID as a decimal value does not
work with the BusyBox shell. Use eval productid + 0 which works
well with bash and BusyBox to convert to a decimal value.
Since the OS Descriptor feature has been reviewed and upstreamed
the USB Gadget library configuration format changed slightly.
Update the configuration files to make sure they work with the
current upstream library version.
go now has its own compile class. Use it and make it work.
snapd uses both autoconf and go, but the autoconf and go class compete
for the configure/compile class, so manually add what is additonally needed
for go.
When compiling for thumb one gets errors like this:
| ../recipe-sysroot-native/usr/lib/arm-angstrom-linux-gnueabi/go/pkg/tool/linux_amd64/link \
| -o $WORK/github.com/snapcore/snapd/cmd/snap/_obj/exe/a.out -L $WORK \
| -L .../recipe-sysroot/usr/lib/arm-angstrom-linux-gnueabi/go/pkg/linux_arm \
| -extld=arm-angstrom-linux-gnueabi-gcc "-extldflags=-march=armv7-a -mthumb \
| -mfpu=neon -mfloat-abi=hard --sysroot=.../recipe-sysroot" -buildmode=exe \
| -buildid=e86c00f573bc1df95256a4a05d36066839bfed34 $WORK/github.com/snapcore/snapd/cmd/snap.a
| # github.com/snapcore/snapd/cmd/snap
| /tmp/go-build238845398/os/user.a(_all.o): unknown relocation type 30; compiled without -fpic?
| invalid rela size 1
| /tmp/go-build238845398/net.a(_all.o): unknown relocation type 30; compiled without -fpic?
| invalid rela size 1
As OE generally hides the build output from the console it does not
clutter the screen, however if something goes wrong the log file
contains important debug info.
meta-snappy now uses go from oe-core.
This commit backports the relevant changes to the recipe.
The OS descriptor changes have been merged upstream, hence we can
use upstream libusbgx again.
In the Toradex Easy Installer we do not use the example programs
or configuration. Create a separate package for the library and
the example programs and configurations.
So far a generic USB vendor and product ID has been used in the
Toradex specific schema files. However, the startup service wrote a
Toradex specific USB product ID. This lead to the awkward combination
of a generic USB vendor ID and Toradex specific product ID.
Use the Toradex vendor ID by default and do not specify the product ID
since it will get filled in by the usbg service.
This allows to use the same schema for Colibri iMX7 with raw
NAND and eMMC flash.
https://github.com/morphis/meta-snappy/commit/f6df6a63756d9976bcccb5fefdbc64e5cc794c99
The Toradex product ID from the config block is decimal coded
ASCII with leading zeros. In C and bash, leading zeros means octal
number... This leads to wrong calculation of the USB product ID
and to errors if the product ID contains the number 8 or 9 (since
those are not valid under the octal numeric system).
Fix both issues by explicitly force decimal system for the Toradex
product ID.
Prevents a warning when not building for one of the machines which have a g1.schema
| WARNING: ...libusbgx/libusbgx_git.bb: Unable to get checksum for libusbgx SRC_URI entry g1.schema: file could not be found
Update libusbgx to a version with OS Descriptor support for better
interoperability with Windows operating systems. Add configuration
using RNDIS with Toradex vendor id. Read serial number and product
id from the device tree to configure the USB gadget device.
libusbgx (libusbg-neXt) is a fork of libusbg which is more actively
maintained.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
Despite the reordering of when to load the USB Gadget configuration
with commit fadb16f153aa ("libusbg: enable USB Gadgets after Connman
to avoid interference") the network device ended up to be down after
startup. It seems that there is a race condition in systemd-networkd
which triggers especially in combination with USB Gadget, a issue on
the systemd issue tracker has been created:
https://github.com/systemd/systemd/issues/1784
There have been various changes related to link handling between
systemd 219 and the latest version 227. It is possible that the issue
is already solved.
Until this has been resolved, explicitly load the USB Gadget before
starting systemd-networkd seems to get around the issue.
