go now has its own compile class. Use it and make it work.
snapd uses both autoconf and go, but the autoconf and go class compete
for the configure/compile class, so manually add what is additonally needed
for go.
When compiling for thumb one gets errors like this:
| ../recipe-sysroot-native/usr/lib/arm-angstrom-linux-gnueabi/go/pkg/tool/linux_amd64/link \
| -o $WORK/github.com/snapcore/snapd/cmd/snap/_obj/exe/a.out -L $WORK \
| -L .../recipe-sysroot/usr/lib/arm-angstrom-linux-gnueabi/go/pkg/linux_arm \
| -extld=arm-angstrom-linux-gnueabi-gcc "-extldflags=-march=armv7-a -mthumb \
| -mfpu=neon -mfloat-abi=hard --sysroot=.../recipe-sysroot" -buildmode=exe \
| -buildid=e86c00f573bc1df95256a4a05d36066839bfed34 $WORK/github.com/snapcore/snapd/cmd/snap.a
| # github.com/snapcore/snapd/cmd/snap
| /tmp/go-build238845398/os/user.a(_all.o): unknown relocation type 30; compiled without -fpic?
| invalid rela size 1
| /tmp/go-build238845398/net.a(_all.o): unknown relocation type 30; compiled without -fpic?
| invalid rela size 1
As OE generally hides the build output from the console it does not
clutter the screen, however if something goes wrong the log file
contains important debug info.
meta-snappy now uses go from oe-core.
This commit backports the relevant changes to the recipe.
https://github.com/morphis/meta-snappy/commit/f6df6a63756d9976bcccb5fefdbc64e5cc794c99
