Create a seperate recipe for each kernel flavour and move the recipe
into the same directory as the kernel recipe.
This allows to have a better control over which machine needs which
device-tree-overlays. E.g. apalis-tk1 does not make use of the NXP
use-mainline-bsp facility.
The downstream kernel gets to old to be used with the new zeus
userspace components. Reuse the apalis-tk1 machine name to build
a mainline kernel and drop the apalis-tk1-mainline machine.
Related-to: ELB-2733
With preempt-rt in overrides, the recipe now builds an RT kernel.
i.e.:
- downloads the rt patch as specified in SRC_URI and applies it
- uses the provided defconfig but modifies the configuration to use
PREEMPT_RT.
Related-to: ELB-2631
Related-to: TOR-992
(cherry picked from commit 64579c21bf256efa9373ff7c030fab4f62a3e07f)
backports-5.4 provides latter drivers.
Squashed cherry-pick which added 5.4 backports.
The main issue that fixes with these backports: the earlier mwifiex
drivers for Marvel 8997 WiFi module stucks on firmware crash (ELB-2596).
Only backported drivers should depend on backported common modules.
Deploying the 99-backports.conf file allows depmod to build modules.dep
dependancies file properly.
Related-to: ELB-2388
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit 43140e494897d670f085425232e57c5ed86b7055)
(cherry picked from commit 1b0f1b0b3c11af54aba3c76c086cedd101dd5202)
(cherry picked from commit a4b3686f00eda0e85ae76a8808229eeccc37406d)
(cherry picked from commit 5ffefe1cb25ebdc5b2db410a4b59fed548973ff4)
(cherry picked from commit d8bf36f3999dcf5805c308dbfa4fbd4ca49d0c17)
(cherry picked from commit 13e31066facf3a28a3458407513e79d2e15aadcc)
(cherry picked from commit 56887d44144c03781d6d08d015ddb3949ca1e03d)
(cherry picked from commit 7fa2f4f8b33caa5dd4beefd85979bd32bd49d86a)
Backports recipe deploys the custom config file for depmod.
Use it in depmodwrapper to generate modules dependencies properly.
Related-to: ELB-2687
(cherry picked from commit ce4619fdc1f2c1c6fcf3b54eaa6fc3bf1d23106c)
NAND support may help (;-p).
Both colibri-imx7 use the same defconfig, however we do not have a
common mx7 override so provide it for each machine.
Add a apalis-tk1-mainline defconfig using the 4.19.59 tegra_defconfig
with enabled CONFIG_PREEMPT_RT_FULL.
Add a default defconfig, use the 4.19.59 arm64 defconfig with enabled
Using "use-mainline-bsp" override removes the SOC specific overrides and thus
the defconfig is not found in the mx7 directory.
Compare with: MACHINEOVERRIDES_EXTENDER_FILTER_OUT in meta-freescale.
While at it, add the use-head-next override which builds head instead
of the pinned version. This is useful for integration work.
Both colibri-imx7 use the same defconfig, only provide it once.
Add a apalis-tk1-mainline defconfig using the 5.4.6 tegra_defconfig.
Add a default defconfig, use the 5.4.6 arm64 defconfig.
(cherry picked from commit bc9a34911adda4efc2930c33c666a6d515fa9f78)
Fix Linux version to really represent 5.4.6.
Update to latest which includes the following two commits:
e87dbbae2576:
ARM: dts: imx7: Fix Toradex Colibri iMX7S 256MB NAND flash support
575bd2d69a82:
arm64: dts: freescale: add initial support for colibri imx8x
(cherry picked from commit f28e4b6a631e0f1c5f1925acc09890176031ef5f)
Bump to latest LTS release Linux 5.4.6 plus Apalis T30/TK1 patches.
(cherry picked from commit ac6df0b7458c551e915cf186481c23401a4b6824)
Bump to latest LTS release Linux 5.4.5.
Bump to latest LTS release Linux 5.4.2.
Implement the new versioning scheme in the Linux mainline recipes. This
leads to a version string like this: 5.3.10-4.0.0-dev+git.401bf3f29b1a
Set the package version to reflect the complete Linux kernel version
plus the git hash it has been built from.
This could be done in the inc file only once, however, the Yocto
kernel recipes set PV in the individual recipies as well. The close
proximity to LINUX_VERSION also makes it obvious what PV will be.
Bump mainline Linux kernel to Linux 5.3.2.
Add initial version of a recipe to build the mainline based PREEMPT_RT
kernel for Toradex modules. This kernel has been maintained for
TorizonCore and is now moving to the official BSP. At this point the
kernel is working well for the platforms supported by TorizonCore,
but the hardware support hasn't been completed or verified.
The defconfig files are the same configurations as generated by the
TorizonCore kernel-cache (kernel configuration metadata) commit
fd3d3be08c05 ("features/usb-net: enable some LTE/GSM modems").
Add initial version of a recipe to build the mainline based kernel for
Toradex modules. This kernel has been maintained for TorizonCore and
is now moving to the official BSP. At this point the kernel is working
well for the platforms supported by TorizonCore, but the hardware
(cherry picked from commit 8109e0a87240489e6bc698e79f2cc748cbe40b17)
(cherry picked from commit 95e057e986e782e85c7ed37e61d27ff389ea4239)
(cherry picked from commit d02ed084d1c4a13e77898affc1b48beabef956f4)
(cherry picked from commit 5bf79f8880f4193bd9c7fd490a25c90383aa0514)
Backports based on 4.19 kernel.
(cherry picked from commit 78e1cdabe0baeb794945bd4926c28058f9f12aa9)
(cherry picked from commit 5d59a8eddb01c439281970496529e0e9a3d6f493)
(cherry picked from commit 56829b6d643fa5dfdac42c0adddf5d41e7fb982e)
(cherry picked from commit 85f6a85b8a8cc400a6f4e201ff5c5cbc43ac1d85)
When building with usrmerge, the firmware directory is in /usr/lib.
Make sure we pickup firmwares from nonarch_base_libdir.
This fixes a build warning when building Torizon:
* Problem 1/1:
* - nothing provides linux-firmware-rtl8188eu needed by linux-firmware-1:0.0+git0+d114732723-r0.all
Add missing space in front of DEPENDS_append in order to avoid issues
caused by further appending.
Since kernel module packages are generated dynamically, the dependency
resolution fails when one requests a specific package which is
generated at build time. Use PACKAGES_DYNAMIC to tell the build system
that backport-kernel-module-* packages can be considered available.
This reverts commit e6641b0a6f93ebf752534b283d0dfb0c2c656ec2.
add coreutils native to depends
in do_configure:
| /bin/bash: line 28: seq: command not found
resulting in do_compile failing:
| In file included from /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/ieee80211_i.h:35:0,
| from /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/status.c:17:
| /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/sta_info.h:460:21: error: field 'hash_node' has incom
| struct rhlist_head hash_node;
Don't use HEAD of branch for every build.
That way we get more reproduciable builds and the git fetcher will not access
the network on every build to check what the current HEAD actually is.
Use KERNEL_VERSION variable instad of running
make kernelversion
Introducing Backports.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
