Since Connman is better suited for more advanced Wireless solutions,
we keep Connman for the main network configuration manager. However,
for the simple RNDIS debug/test configuration, Connman is not well
suited since Connman tries to maintain one connection only at any
given time.
This change enables networkd and adds a simple standard configuration
for USB/RNDIS network devices.
When the link goes down, the DHCP service has been disabled, while
there is no corresponding functionality which enables the service
when the link goes up again. This fix is taken from systemd 217.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
- Make sure leases file is not persistent (in /var/run now)
This allows to serve the same IP to the generated (and hence
different IP addresses)
- Start RNDIS service after the network.target
- Tegra: Add extra service for udhcpd. When running dhcpd directly
from udev, the daemon will be killed after a while
meta-angstrom now overrides the effect of the patch and provides the
journald.conffile in full.
To override a setting either create the file with your settings in
meta-toradex/recipes-core/systemd/systemd/journald.conf or
edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
Disable USB RNDIS systemd service for now due to possible race upon
first boot:
[ OK ] Started Load/Configure the kernel driver providing the RNDIS
gadget.
=> system hang
ifconfig does no longer understand 192.168.11.2/24 and its
use is deprecated, so instead of changing to another way of
stating the subnetmask use /sbin/ip.
i.MX6 and Vybrid modules use the g_ether driver for RNDIS functionality.
This commit uses a systemd service to load the kernel module, configures the new
usb0 NIC and starts a dhcp server to serve an IP address to a USB host.
The Tegras use the android gadget driver. The configuration remains unchanged.
Patch pending in meta-angstrom
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
If the path is appended by someone else, the space introduces an error
Add the fstrim utility to Colibri T30 image. The utility allows to
send trim commands to the underlaying flash translation layer, which
allows too free not used flash sectors and those improve wear-
leveling
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size.
On first boot this filesystem is resized to fill its full partion.
This slows down IO responsivness during the first 5 minutes.
- these partitions are not meant to be mounted
- add recipe which configures RNDIS and dhcp on the new NIC
requires kernel commit b7e977a36ee2b1ab1a55238761fe8d63df9bc638
see also http://permalink.gmane.org/gmane.linux.usb.general/56244
