Create symlinks for each supported by Verdin iMX8M Mini ADC channels,
standardizing names as verdin-adcX, according to the Verdin signal names
table.
Related-to: ELB-2839
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Create symlinks for each supported by Colibri iMX6 ADC channels,
standardizing names as colibri-ainX, according to the Colibri signal
names table.
Create symlinks for each supported by Colibri iMX7/iMX7-eMMC
ADC channels, standardizing names as colibri-ainX, according
to the Colibri signal names table.
Create symlinks for each supported by Colibri iMX6ULL ADC channels,
names table.
names table.
Create symlinks for each supported by Apalis iMX8QXP ADC channels,
standardizing names as apalis-adcX, according to the Apalis signal names
table.
Create symlinks for each supported by Apalis iMX8 ADC channels,
table.
Create symlinks for each supported by Apalis iMX6 ADC channels,
table.
Related-to: ELB-2760
The I2C DDC channel serves by HDMI driver in the mainline kernel.
Add udev rules to make a symlink for this device.
Related-to: ELB-2784
According to the internal document "Hardware interfaces
standardization", the UART interfaces should be accessed
via device nodes named with the module family and matching
the signal name used in the module datasheet.
Modify udev rules for UART devices accordingly.
Related-to: ELB-2787
There are 2 different names for spi use by downstream and upstream
kernel. Fix the udev rules to match both variants.
The last user of this were the Tegras using the downstream kernel which
were dropped. Drop the recipe.
Related-to: ELB-2733
- Drop deprecated NATIVE_SYSTEMD_SUPPORT.
- Drop do_compile, base_do_compile would be good enough.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
- Drop FILES_${PN}, it's redundant.
This adds udev rules for symlinking eMMC devices consitently.
Related-to: ELB-2380, ELB-2696
This commit adds rules to udev so apalis/colibri or verdin spi
devices are symlinked consistently.
Related-to: ELB-2380, ELB-2598
Disable configuration of wired interfaces by systemd-networkd.
Also provide an option which will force to keep ip configuration in case
of critical connection (rootfs mounted via nfs etc.).
Relates-to: ELB-2610
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
These rules make sure that a symlink is created for all i2c and tty
devices. This symlinks are named like on the Toradex carrier boards.
This makes it easy to identify which device in software is matching
the hardware pins.
Additional non-standard devices that are not named clearly on the
carrier board are left out to prevent confusion.
(cherry picked from commit 47ef64803548f73a0eda753c5d3d3f7f315af606)
This will generate a hostname based on machine name and serial number.
(E.g. colibri-imx7-031111777)
If serial number is not found it will say "no-serial-number" in host
name.
If machine is not supported hostname will include "unsupported-device"
string.
If /dev/device-tree does not exist it will say "recovery-mode"
as it assumes its in recovery mode of Toradex Easy Installer
To prevent openembedded from creating /etc/hostname file
add hostname_pn-base-files = "" to configration
Related-to: TEI-100, ELB-1322
Signed-off-by: Luka Pivk <luka.pivk@toradex.com>
Since oe-core commit 3150253898ba ("systemd-conf: simplify
creation of machine-specific configuration") systemd-conf no
longer unpacks the systemd sources. Hence the patch which patches
units/systemd-udevd.service.in does no longer apply.
Apply the patch in the systemd recipe instead.
The systemd-udevd.service file is only deployed in a package
built from the systemd recipe anyway, hence this also makes sure
that the patched file gets actually deployed.
This essentially reverts commit 118f6b1b17b6 ("systemd: follow
recipe split which added systemd-conf").
Upstream has changes in the context lines.
The patch is not obsolete AFAIKT.
i.e. the configuration file should NOT make mounts by udevd private or
other processes will not be able to see the mount.
This reverts commit 3640a12c85df4ac180e38f19038072df6b1d6d55.
That patch has been merged to systemd-conf.
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Or else the changes for systemd-conf recipe will be missed.
The systemd configuration has been split from the systemd recipe.
Thus we need to move our changes to the systemd configuration.
While at it drop the kmod packageconfig. This was only needed with angstrom.
These machines use an old Nvidia provided downstream kernel 3.1.10. They no
longer much the way more recent sysroot components, e.g. libc, xserver et. al.
The maintance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
This starts a service which inserts kernel modules on boot.
Updates in meta-angstrom removed this default packageconfig.
Keywords in udevd.service.in were changed upstream.
OE-core dropped to do this for whatever reasons.
Compare with openembedded core, commit 6c1765a05c1321f08f3d1fb521dfe6b07bc8e92
* Drop mount propagation patch, it only happens with libseccomp, OE doesnt
enable it
This reverts commit a8ee603737444c74db61d0a705b08e9a1dea5158.
The patch is forward ported to systemd 234.
Use '${COMMON_LICENSE_DIR} for license files
fix the warning:
| WARNING: packagegroup-xfce-base-1.0-r5 do_populate_lic:
| ${COREBASE}/LICENSE is not a valid license file, please use
|'${COMMON_LICENSE_DIR}/MIT' for a MIT License file in LIC_FILES_CHKSUM.
|This will become an error in the future
Configure the read_ahead cache size to optimal value, for the
mmcblk devices (eMMC and SD card).
The cache values are module specific, tests were run on the pre-built
image (BSP V2.7 Beta 1). The measurement of read speed for a range of
cache sizes (16kB to 256MB) was made using hdparm -t.
Signed-off-by: Leonardo Graboski Veiga <leogveiga@gmail.com>
In case the resizefs.sh script ends quite fast, the system might still
be in boot sequence. Removing a systemd service can be problematic
in that case: It seems that systemd looses the state of .device units,
and some services depend on such units (namely serial consoles such as
serial-getty@ttymxc0.service). The following sequence shows this problem:
Jan 12 00:16:45 apalis-imx6 sh[399]: Removed /etc/systemd/system/multi-user.target.wants/resizefs.service.
Jan 12 00:16:45 apalis-imx6 systemd[1]: Reloading.
Jan 12 00:16:45 apalis-imx6 root[704]: resizing mmcblk0p2 finished, new size is 3755M
Jan 19 00:04:08 apalis-imx6 systemd[1]: dev-ttymxc0.device: Job dev-ttymxc0.device/start timed out.
Jan 19 00:04:08 apalis-imx6 systemd[1]: Timed out waiting for device dev-ttymxc0.device.
Jan 19 00:04:08 apalis-imx6 systemd[1]: Dependency failed for Serial Getty on ttymxc0.
(the time has been updated between this to events, but that does not
influence the issue)
Using --no-reload avoids the "Reloading." message above and seems to not
cause such issues anymore.
The script used for all machines (e.g. T30) and the mx6 specific
script are the very same scripts. Drop the mx6 specific script,
with that the recipe will use the general scripts for all machines.
The BSP should automount for all users.
The Demo Software Layers cares for RNDIS.
oe-core moved the mountpoint used to /run/media/<drive>.
In our setup we don't see issues with /media being read only
when udev starts mounting.
In our environment with graphical desktop udisks will later take over
the automount job and udisks currently still uses /media,
so keep this consistent between mounting at boottime and mounting at runtime.
Refer to openembedded-core commits:
acfe3014d41de5e87cdbc58d0396349c6b9c3ffd
62ae16c40252f39ba28e072218d67f47b26b3535
Non graphical images will never execute graphical.target services.
With fido e2fsprogs did split out the package e2fsprogs-resize2fs.
RRECOMMEND it so that it gets picked up during rootfs creation.
We noticed that our latest move to using systemd/networkd leaves the
rndis0 interface down. Manually bringing the link up solved the issue.
As a workaround add upping the link to our start-rndis.sh script.
This reverts commit bd2d32bf3a8460c87849e75ad01e11450d8cda10.
Remove the backport, is part of fido.
Angstom Dizzy now uses systemd V218 so there is no need to build
a component seperately anymore.
This reverts commit 16b8b392ad048566729f30d7c3887d1bfdf21bd4.
