2013-06-26 | systemd: fix patch path so the default -p 1 applies | Max Krummenacher | |
2013-06-26 | fs-init: add recipe to extend rootfs partition on eMMC | Max Krummenacher | |
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size. On first boot this filesystem is resized to fill its full partion. This slows down IO responsivness during the first 5 minutes. | |||
2013-06-26 | udev: don't try to automount mmcblk0bootX | Max Krummenacher | |
- these partitions are not meant to be mounted | |||
2013-06-07 | systemd-journald: limit journal size | Max Krummenacher | |
2012-12-17 | rndis: set a revision in recipe, limit leases to 1 | Max Krummenacher | |
2012-12-07 | usb-rndis: make sure the interface is up when a host connects | Max Krummenacher | |
2012-11-26 | usb-rndis: | Max Krummenacher | |
- add recipe which configures RNDIS and dhcp on the new NIC requires kernel commit b7e977a36ee2b1ab1a55238761fe8d63df9bc638 see also http://permalink.gmane.org/gmane.linux.usb.general/56244 | |||
2012-08-24 | ${BPN} errors to psplash-angstrom instead of psplash, fetch fails. | Max Krummenacher | |
