Create symlinks for each supported by Verdin iMX8M Mini ADC channels,
standardizing names as verdin-adcX, according to the Verdin signal names
table.
Related-to: ELB-2839
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Create symlinks for each supported by Colibri iMX6 ADC channels,
standardizing names as colibri-ainX, according to the Colibri signal
names table.
Create symlinks for each supported by Colibri iMX7/iMX7-eMMC
ADC channels, standardizing names as colibri-ainX, according
to the Colibri signal names table.
Create symlinks for each supported by Colibri iMX6ULL ADC channels,
names table.
names table.
Create symlinks for each supported by Apalis iMX8QXP ADC channels,
standardizing names as apalis-adcX, according to the Apalis signal names
table.
Create symlinks for each supported by Apalis iMX8 ADC channels,
table.
Create symlinks for each supported by Apalis iMX6 ADC channels,
table.
Related-to: ELB-2760
The I2C DDC channel serves by HDMI driver in the mainline kernel.
Add udev rules to make a symlink for this device.
Related-to: ELB-2784
According to the internal document "Hardware interfaces
standardization", the UART interfaces should be accessed
via device nodes named with the module family and matching
the signal name used in the module datasheet.
Modify udev rules for UART devices accordingly.
Related-to: ELB-2787
There are 2 different names for spi use by downstream and upstream
kernel. Fix the udev rules to match both variants.
This adds udev rules for symlinking eMMC devices consitently.
Related-to: ELB-2380, ELB-2696
This commit adds rules to udev so apalis/colibri or verdin spi
devices are symlinked consistently.
Related-to: ELB-2380, ELB-2598
These rules make sure that a symlink is created for all i2c and tty
devices. This symlinks are named like on the Toradex carrier boards.
This makes it easy to identify which device in software is matching
the hardware pins.
Additional non-standard devices that are not named clearly on the
carrier board are left out to prevent confusion.
(cherry picked from commit 47ef64803548f73a0eda753c5d3d3f7f315af606)
These machines use an old Nvidia provided downstream kernel 3.1.10. They no
longer much the way more recent sysroot components, e.g. libc, xserver et. al.
The maintance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
Configure the read_ahead cache size to optimal value, for the
mmcblk devices (eMMC and SD card).
The cache values are module specific, tests were run on the pre-built
image (BSP V2.7 Beta 1). The measurement of read speed for a range of
cache sizes (16kB to 256MB) was made using hdparm -t.
Signed-off-by: Leonardo Graboski Veiga <leogveiga@gmail.com>
oe-core moved the mountpoint used to /run/media/<drive>.
In our setup we don't see issues with /media being read only
when udev starts mounting.
In our environment with graphical desktop udisks will later take over
the automount job and udisks currently still uses /media,
so keep this consistent between mounting at boottime and mounting at runtime.
Refer to openembedded-core commits:
acfe3014d41de5e87cdbc58d0396349c6b9c3ffd
62ae16c40252f39ba28e072218d67f47b26b3535
- these partitions are not meant to be mounted
