Create symlinks for each supported by Colibri iMX7/iMX7-eMMC
ADC channels, standardizing names as colibri-ainX, according
to the Colibri signal names table.
Related-to: ELB-2839
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
According to the internal document "Hardware interfaces
standardization", the UART interfaces should be accessed
via device nodes named with the module family and matching
the signal name used in the module datasheet.
Modify udev rules for UART devices accordingly.
Related-to: ELB-2787
There are 2 different names for spi use by downstream and upstream
kernel. Fix the udev rules to match both variants.
Related-to: ELB-2784
This commit adds rules to udev so apalis/colibri or verdin spi
devices are symlinked consistently.
Related-to: ELB-2380, ELB-2598
These rules make sure that a symlink is created for all i2c and tty
devices. This symlinks are named like on the Toradex carrier boards.
This makes it easy to identify which device in software is matching
the hardware pins.
Additional non-standard devices that are not named clearly on the
carrier board are left out to prevent confusion.
(cherry picked from commit 47ef64803548f73a0eda753c5d3d3f7f315af606)
