path: root/recipes-bsp
2016-09-29u-boot: get rid of obsolete patchesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-12-15Update all U-Boot versions to latestMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15Apalis iMX6: U-Boot: change name for IT modulesMax Krummenacher
Change the name form u-boot-it.imx to u-boot.imx-it. This prepares for the upcomming move of the i.MX 6 based modules BSP to meta-fsl-arm-extra. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-08-07colibri-vf: use U-Boot recipe from meta-fsl-arm-extraMax Krummenacher
2015-05-18Apalis/Colibri: update U-Boot to latestMax Krummenacher
And use 2015.04-toradex branch
2015-05-18Apalis/Colibri: update U-Boot to latest in -nextMax Krummenacher
2015-05-18Apalis iMX6 IT: u-boot: use the IT defconfig for ITMax Krummenacher
2015-05-12update to latest u-bootMax Krummenacher
2015-05-12update U-Boot and Colibri VFxx Linux to latest git revisionStefan Agner
2015-05-12update to latest u-bootMarcel Ziswiler
2015-05-12u-boot: use latest from gitMax Krummenacher
While at it remove warning about stripped fw_printenv binary when building u-boot-toradex-fsl-fw-utils.
2015-05-12Apalis/Colibri iMX6: kernel/U-Boot update to latest in -nextMax Krummenacher
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module.
2015-05-12colibri_vf: update to U-Boot 2015.04/Linux 4.0Stefan Agner
2015-05-12licenses: fix license string to known values or formatMax Krummenacher
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-02-03colibri-vf: update Linux kernel and U-Boot git hashesStefan Agner
Also update default defconfig for colibri-vf.
2015-01-09u-boot: build additional binary for Apalis iMX6Q 2GB ITMax Krummenacher
The IT variant needs different RAM timings
2014-12-19u-boot/u-boot-fw-utils: update all to latestMax Krummenacher
2014-12-19colibri_vf: update U-Boot and Linux kernel git hashesStefan Agner
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze.
2014-12-18Update all to latest and greatest U-Boot and Linux kernel.Marcel Ziswiler
2014-12-16colibri-vf: switch to mainline kernel based on 3.18Stefan Agner
Switch default kernel recipe to linux-toradex-vf which will build a kernel based on the toradex 3.18-next branch.
2014-12-11colibri-vf: update U-BootMax Krummenacher
2014-12-11apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1Max Krummenacher
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules
2014-10-30u-boot: iMX6/VF update to latest from gitMax Krummenacher
2014-10-20colibri-vf: u-boot: switch to 2014.10Stefan Agner
Use rebased U-Boot release 2014.10. The README has a new md5sum and U-Boots new build system has default configurations ending with defconfig too.
2014-10-06colibri-imx6: refactor recipes for new moduleMax Krummenacher
2014-10-06u-boot: remove don't build the examples patchMax Krummenacher
u-boot.inc no longer builds the standalone examples by default so do patch to not do so is no longer needed. The source tree will no longer be marked as git dirty.
2014-08-04u-boot: update to latest git versionMax Krummenacher
2014-08-04u-boot-toradex: update to latest git versionMax Krummenacher
2014-08-04gpio-export: fix gpios-export.serviceMax Krummenacher
2014-08-04gpio-export: add recipe for userspace export of gpiosMax Krummenacher
2014-08-04mcc/m4: use recipes from meta-fsl-armMax Krummenacher
deleted: recipes-bsp/libmcc/libmcc_1.04.bb deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb
2014-05-24colibri-vf: use latest u-boot and burnflashMarcel Ziswiler
Use the latest U-Boot and burnflash.
2014-05-07u-boot: make use of shared U-Boot branchStefan Agner
2014-04-30colibri-vf: switch to U-Boot 2014.04 and latest gitStefan Agner
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location.
2014-04-03u-boot: apalis-imx6 update to latest git versionMax Krummenacher
2014-04-02u-boot: apalis-imx6 update to latest git versionMax Krummenacher
2014-04-01u-boot: convert bbappend to a bbMax Krummenacher
2014-04-01u-boot: add Apalis iMX6 and Colibri VF recipeMax Krummenacher
2014-04-01colibri-vf: use meta-fsl* layer for BSP filesMax Krummenacher
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
2014-03-26mqxboot/libmcc: fixed dependencies to kernel moduleStefan Agner
We need to have the kernel modules header at build time, so mark it as not only a runtime dependency.
2014-03-18u-boot Txx: update to latestMax Krummenacher
2014-03-17kernel/u-boot: update to latest git revisionStefan Agner
2014-03-17vybrid: backport Cortex-M utilites from meta-fslStefan Agner
- Add utility mqxboot to load firmware into IRAM and reset M4 - Add kernel module mcc needed by libmcc - Add multi-core communication library libmcc for message queue based communication with Cortex-M core
2014-02-10kernel/u-boot: update to latest gitStefan Agner
2013-11-21u-boot: colibri-vf: use the unified u-boot 50/61Max Krummenacher
2013-11-21Machine: use the changed machinename colibri-vfMax Krummenacher
